High-end torque and gear question. - Mustang Evolution
Old 05-11-2009, 07:24 PM   #1
ya me again.
ok like i said the studdering problem is gone.......but not at higher speeds say going from 75-100 the car seems to take more than it usualy does to get there. Any ideas? I'm not looking to spend lotta money but more of like tests to see if there a problem.
Car pushes easly in nuetral with no problem or grindings.
Them super computer 3 diff ones said there nothing wronge with motor at all.
I run 89 gas, brand new autolight plugs, brand new wires, brand new coils,cold air,flow-masters cat back.
Other than that the car seems to run fine.
Now my other problem is when i shift it is rediculiously hard to shift. Like i have to realy pull and push the shifter and I'm not a weak guy(325lb bench press). It feels as if the gears are cetching ever so lightly when i'm going to shift. And reverse is damn near impossible to get into you have to work it in there for a good 30 seconds.
also the shifter gets mighty warm buring driving...not burning warm but warm warm.
Please keep in mind im flat broke with not alot of money to waste. Any help?
eddie1 is offline   Reply With Quote
Old 05-11-2009, 09:38 PM   #2
Re: High-end torque and gear question.
adjust your clutch, it should have pressure as you push it in pretty quick not like a inch or two from the floor
Old 05-12-2009, 12:04 AM   #3
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
syncros? (dunno how you spell that, but i'm sure you know what i mean)
they are supposed to make it easier to go into gear, so if ur havin a hard time... but iirc it usually starts having problems in one gear first than moves to others, i believe i heard 3rd was usually the first to have problems...
dunno if this is a good question or not (i haven't followed your progess or the problem from the beggining, only this one post) but your tranny fluid is topped off right?
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Rear End Gear FAQ OsirisGuy General Mustang Discussion 18 11-10-2009 12:22 AM
CAI, losing low end torque? Dude87 1996-2004 Mustang GT 1 09-16-2008 07:59 AM
'69 fastback frame rail/torque box question--with pics helrazr70 Classic Mustangs 2 07-01-2008 07:53 PM
1996 Mustang GT rear end gear ratio Buzz 1996-2004 Mustang GT 2 04-23-2006 07:19 PM
Rear end gear!!!!!!!!!!!!!!!! coolstang Pre-2005 V6 Mustang 27 11-10-2004 12:56 AM
05:44 PM
