It won't run - Mustang Evolution
Old 05-21-2009, 05:40 PM   #1
upton7's Avatar
It won't run
My car has been sitting two days because i need to get my exhuast leak fixed i was getting ready to take it to the shop and it would take like 5-7 seconds to turn over then it ran really rough for a couple seconds then it just died. What should i do?
Old 05-21-2009, 05:58 PM   #2
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: It won't run
check the basics, air, fuel, spark... cel?
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 05-21-2009, 06:46 PM   #3
hottcobra's Avatar
Re: It won't run
sounds like a bad battery, try to jump start it and see what it does.
Old 05-21-2009, 08:34 PM   #4
SaleenFiend's Avatar
Re: It won't run
I was going to say alternator, maybe a combination...
Old 05-21-2009, 08:53 PM   #5
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: It won't run
There is absolutely no way to tell with so little information.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 05-21-2009, 08:55 PM   #6
upton7's Avatar
Re: It won't run
i got it goin it was the the leak ig or for sitting for a few days
what should i run? 07stang General Mustang Discussion 26 03-11-2009 07:50 PM
Had a run-in with a GT... MarkuzLS1 The Bar 15 03-01-2007 09:01 PM
run in with 5.0 lx a00v6stang The Bar 23 01-02-2006 06:52 PM
Had a run it with a '02 GT Scoot99V6Stang The Bar 33 12-11-2005 03:24 AM
Trying to run 14.5 cms09071987 Pre-2005 V6 Mustang 12 08-25-2005 04:56 PM
03:38 AM
