pop - Mustang Evolution
Old 05-24-2009, 09:29 PM   #1
upton7's Avatar
pop
Started my car today to go wash it on my concrete patch and i put it in reverse lowered the e brake and backed up about an inch and heard a POP then it ran ok. When i moved it in the driveway i put it in first lowered the e brake and again heard a POP after that it ran ok again.
Old 05-24-2009, 09:33 PM   #2
Otlaw80's Avatar
Re: pop
pop from the motor? exhaust? front end? rear end? could be E-brake sticking, either the cable or the caliper, could possibly be a ball joint (usually only when turning though).
Old 05-24-2009, 10:01 PM   #3
upton7's Avatar
Re: pop
sounds like its either near the driveshaft or rear end its like a metal pop not an exhuast pop but i did put on a new o/r pipe and had some problems with it but i thought i got it fixed
Old 05-24-2009, 10:02 PM   #4
upton7's Avatar
Re: pop
how would i know if the e brake is sticking?
Old 05-24-2009, 11:06 PM   #5
Otlaw80's Avatar
Re: pop
easiest way to tell is put the e-brake on, start the car, release the brake and put it in gear. Without hitting the gas see if the car moves under its own power. if its stuck it will either not move or it will move slower than normal.
U joints can also cause a pop noise when u put it in gear if they are wore out.
Old 05-25-2009, 07:42 PM   #6
upton7's Avatar
Re: pop
thanks bro
Old 05-25-2009, 08:26 PM   #7
upton7's Avatar
Re: pop
if the ebrake is stuck what do i do
Old 05-25-2009, 08:34 PM   #8
Otlaw80's Avatar
Re: pop
Its usually the cables that stick. Find where they connect to the rear caliper. The cable consists of 2 parts. The cable itself, then the black sleeve that goes over it. Use some WD-40 or PB blaster or some sort of penetrating oil to spray in between the cable and sleeve as good as u can, on both sides. Also, spray down where it hooks to the caliper and the spring. Work the E-brake a few times and do it again, etc. There are usually 3 cables. One from the brake handle in the car, and then one to each rear caliper. Wich means there is another joint where they hook together. Usually in the middle of the car, underneath. Though i have seen some under the back seats. You may have to do the same thing at that joint.
Old 05-25-2009, 08:39 PM   #9
upton7's Avatar
Re: pop
i just got in it did what you said and went back in reverse it rolled back fine but there was a lil pop not like i heard before i'll try it again here in about 30 minutes
Old 05-25-2009, 08:44 PM   #10
Otlaw80's Avatar
Re: pop
Do you use the brake all the time? Just start using it? Not use it for a couple days after the car getting wet?
It could also be something completely different. I've heard little creaks and pops from a caliper sticking caused by the guide pins being stuck. Possibly even something in the rear end getting a little loose, but that would prob do it every time u started to move.
Old 05-25-2009, 08:48 PM   #11
upton7's Avatar
Re: pop
i bought the car in february and i always use the e brake and i'm sure the guy before me did cuz when i test drove it he had it engaged. Should i take one of the rear wheels off to see if the cable is engaged?
Old 05-25-2009, 08:53 PM   #12
Otlaw80's Avatar
Re: pop
it wouldn't hurt, if you have someone that can give you a hand. Have them engage the brake while you watch the caliper. then have them release it. See if the cable moves back right away. It should move back pretty quick, and make sure its about the same distance it moved when the brake was engaged. Check both sides. While you have the car jacked up, it would be a good time to check the u-joints also. Grab the drive shaft in one hand and the yolk in the other and try to twist them opposite ways. They should not twist. Do this at the front and rear of the drive shaft. Make sure you use something to chock the front wheels and use jack stands
Old 05-25-2009, 09:07 PM   #13
Re: pop
Some of these cars just have weird pops...Tiff's 04 GT does it all the time. Sounds like something hitting the floorpan but there's nothing down there and hasn't ever messed anything up...
Old 05-26-2009, 01:52 AM   #14
MonteCitan's Avatar
Re: pop
Does it sound and feel like it's hitting the floor pan?
is it noticeable every time the engine/trans loads up? (IE putting it in gear, accelerating, etc)
My 01 GT was doing the same thing pretty bad and it was actually phyiscally missing the trans mount to trans bolts.. so trans itself was hitting the tunnel..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 05-26-2009, 01:55 AM   #15
upton7's Avatar
Re: pop
It could be something hitting the floor pan but i don't know for sure i'm gonna see if i can get it on a lift tomorrow and see what the **** is really goin on
Old 05-26-2009, 06:59 AM   #16
SaleenFiend's Avatar
Re: pop
Good thing you don't have an irs, or a t56 the cluckings never end!
Old 05-26-2009, 07:44 AM   #17
Re: pop
on a lowered car the e brake mount can rub on the driveshaft but thats only on cars that are really low
I Wanna Be A Pop Star Brent Pictures and Videos 10 09-27-2007 11:18 PM
Pop Up Ads Brent ME Site Help & Announcements 1 03-04-2007 02:13 PM
ITS POP *****ES!!!!! :) Zim The Bar 121 05-12-2006 08:41 AM
saddam is a pop star???? fast64 The Bar 1 12-27-2003 07:47 PM
so i was eating pop corn Rellik The Bar 4 10-22-2003 01:58 PM
02:21 PM
