Valve Cover removal - Mustang Evolution
Old 05-26-2009, 11:49 AM   #1
upton7's Avatar
Valve Cover removal
I' gonna have my normal auto body guy paint my valve covers ford blue. I'm going to take them off and and let him paint them then i will put them back on. My question is do you just take out the bolts and unplug the hoses. and just not drive or is there more to it?
Old 05-26-2009, 12:22 PM   #2
hottcobra's Avatar
Re: Valve Cover removal
no that's about it. you just remove the bolts and any hoses and wires that are in the way. If the car doesn't sleep in a garage. you need to cover the valvetrain area that is covered by the valve covers with garbage bags or some other type of moisture barrior. and tape it down so it doesn't come off.
Old 05-26-2009, 01:42 PM   #3
I would personally buy a spare set and get them done how you want then swap them on so there is no time left where the valve covers are not on the car
Old 05-26-2009, 01:43 PM   #4
SaleenFiend's Avatar
Make sure you change the gaskets, unless you already have very very recently
Old 05-26-2009, 04:11 PM   #5
the passenger side will lift straight up when u unbolt it and take it off but the driver side will have to be tilted a few times to come out because of the hydroboost. when u get it painted i recommend u tape the driver side valve cover up pretty good to avoid scratches when trying to snake it by the hydroboost.
96 GT- Who knows what's in it.
Old 05-26-2009, 05:46 PM   #6
upton7's Avatar
How much are they and how do I do it?
Old 05-26-2009, 06:03 PM   #7
upton7's Avatar
and could i clearcoat them? or would i just be askin for trouble i think i'm gonna do it all myself
Old 05-26-2009, 06:30 PM   #8
iirc the gaskets were 20 bucks and they are rubber gaskets, which can be reuseable.
Old 05-26-2009, 08:37 PM   #9
upton7's Avatar
iirc and do i just sit them on top of the head or do i need to put some kinda adhesive down fist and should i buy new ones?
Old 05-26-2009, 11:13 PM   #10
the valve covers have little grooves that the gasket pretty much inserts into.
Old 05-26-2009, 11:42 PM   #11
upton7's Avatar
so just stick it in the grooves and bolt em down?
Old 05-27-2009, 12:08 AM   #12
pretty much, u can dab a little bit of rtv in the groove to insure the gasket will stay in place while installing the valve covers.
Old 05-27-2009, 01:51 AM   #13
2007STANG's Avatar
Region: West Virgina
Remember don't over tighten them they can worp/crack then you will be facing leaks:
2007STANG is offline   Reply With Quote
Old 05-27-2009, 01:54 AM   #14
upton7's Avatar
Whats the torque specs?
Old 05-27-2009, 01:56 AM   #15
2007STANG's Avatar
I never torgued them just snug let the gasket do its job if you smash it to much it will not seal
Old 06-04-2009, 07:43 AM   #16
tq spec is 71-106 in-lbs. I know when I did my top end my xtrans dipstick was kinda in the way of removal and installing. but it was just a matter of maneuvering it.
2kslvrgt is offline   Reply With Quote
valve cover question 93yellowgt 1979-1995 Mustang GT 3 06-07-2009 11:06 PM
front bumper cover removal topbliss 2005-2010 Mustang GT 10 06-07-2008 07:51 AM
valve cover? Fishers Stang Pre-2005 V6 Mustang 4 04-17-2006 07:44 PM
new valve cover in Thomas91169 Pictures and Videos 9 04-03-2005 05:12 PM
valve cover leak... 98GreenStallion Pre-2005 V6 Mustang 1 12-03-2004 06:43 PM
06:03 PM
