96 gt rear swap - Mustang Evolution
Old 06-02-2009, 10:21 AM   #1
Lightbulb 96 gt rear swap
can anyone tell me if a 8.8 rear 3.73 gears from a 98 explorer will fit my 96 gt? If so what i will need to make the swap? I can get one for a good price rotor 2 rotor calipers included. I'm thinking it will also change my axles from 28 to 31 splines? Any help or info will be greatly appreciated thanks
jk7208 is offline   Reply With Quote
Old 06-03-2009, 09:21 AM   #2
SaleenFiend's Avatar
Re: 96 gt rear swap
Yea, the gears should swap right over as both should have an 8.8" rear end. You will probably get a whine or roar though as the gears will probably already have a gear wear pattern and it is nearly impossible to match it. When you do the swap be sure to check the run out on your carrier. You will need differential fluid, friction modifier, a crush sleave, and tools such as a pinion depth finder, mic, and a few others that don't come to mind right not. I suggest changing the bearings while there also (Inner/Outer Pinion)
I'm not sure about the swap from 28 to 31 Spline but if so you would just need to change the whole carrier and axles if they fit into your housing.
rear end swap 98mustang2007 Pre-2005 V6 Mustang 2 11-11-2007 06:21 PM
doing a rear end swap in the morning jimmy_beaner The Bar 7 05-20-2005 09:47 PM
Rear end swap Sublime782 Pre-2005 V6 Mustang 20 03-26-2005 07:13 PM
Rear End Swap Ken Pre-2005 V6 Mustang 13 10-02-2003 01:49 PM
finished my rear end swap Monkey Pre-2005 V6 Mustang 3 07-27-2003 05:23 PM
08:20 PM
