POSSIBLE NEW ENGINE - Mustang Evolution
Old 06-02-2009, 09:28 PM   #1
upton7's Avatar
POSSIBLE NEW ENGINE
My freind who is a big mustang man is taking out an engine of one of his freinds new edge mustangs. I guess one of the piston rings went out and needs new bearings. He said I could probably get it for under 200 dollars since the guy is putting in a brand new complete long block. He said i'd get everything from the intake down to the oil pan. I plan on putting it on my dad's engine stand and just cleaning it very well and put the ring and bearings in myself. Anyone with advice tips and opinions will be apppreciated.
Old 06-02-2009, 10:43 PM   #2
Re: POSSIBLE NEW ENGINE
well this would be a perfect time to install cams and possibly heads. it is definitely easier to time the motor with it out of the vechile, i did mine while it was in the car, but a little more space would have been helpful. themustangdepot.com has some good prices on 4.6 internal parts.
96 GT- Who knows what's in it.
Old 06-03-2009, 08:43 AM   #3
SaleenFiend's Avatar
I'd push him for $150.00. I'm sure he can't say No...
Old 06-07-2009, 11:22 PM   #4
Otlaw80's Avatar
If you decide you don't want it, let me know :whistle: Other than that it would be a great time to take it slow and build it up
Old 06-08-2009, 12:42 AM   #5
upton7's Avatar
if i can get it i'm gettin it and i'm just gonna slowly make it a really strong bottom end so it can run a good nitrous shot or maybe some boost
Old 06-08-2009, 12:47 AM   #6
upton7's Avatar
They do have really good prices. I saw a stroker kit for about 700 would i have to have it line bored or anything or do i put it in like the stock one and just get it tuned?
Old 06-08-2009, 07:08 AM   #7
ive yet to see a 05+ engine in a pre 05 might be interesting
Old 06-08-2009, 06:23 PM   #8
to install a stroker kit, u will have to get the block stripped down and machined so all the parts will fit and work correctly. u can get a block machined for a decent price.
Old 06-08-2009, 08:48 PM   #9
upton7's Avatar
its not an 05+ its a 2001
Old 06-08-2009, 08:49 PM   #10
upton7's Avatar
i'm strippin down the block neway should i do it?
Old 06-09-2009, 01:45 AM   #11
hell yea, im more than positive u will love the results once u get the motor in your car.
Old 06-09-2009, 09:40 PM   #12
upton7's Avatar
will i need to bore anything or have proffesional work done?
Old 06-10-2009, 12:40 AM   #13
i would have the machine work professionally done to make sure everything is lined up, especially a high revving mod motor.
Old 06-10-2009, 02:30 PM   #14
upton7's Avatar
u know how much that would run?
Old 06-10-2009, 10:51 PM   #15
it varys, i have seen it from 3-600 dollars.
Old 06-11-2009, 08:04 AM   #16
2007STANG's Avatar
Region: West Virgina
what are you trying to do just get it running or complete rebuild
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 06-11-2009, 02:45 PM   #17
upton7's Avatar
rebuild and get as much hp as i can
Old 06-12-2009, 05:50 PM   #18
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
make sure you look at the stroker kit... some are designed for over bored cylinders, basically you'll have to take the block in and get it surfaced ne way (i think thats what its called) and if the cylinders are crap than have it bored out and than get a stroker kit for that...
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 06-12-2009, 08:56 PM   #19
upton7's Avatar
when it gets bored how manyt liters will it be 4.7? 284?
Old 06-13-2009, 04:06 AM   #20
Region: Oregon
depends on how much you bore it and what stroker kit you get for it or if you leave it stock... but i won't be able to tell you those #s or what is a good kit cause its a newer engine that i haven't researched that much, but i'm sure someone has some good info on this...
V6 Engine Help kack85 Pre-2005 V6 Mustang 3 01-08-2009 09:37 PM
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 07:40 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
New Engine!!!! drummerstang98 The Bar 18 01-02-2005 04:38 PM
11:12 AM
