Does anybody know - Mustang Evolution
Old 02-23-2005, 11:15 AM   #1
Does anybody know
about driveshafts? Sorry Brent I know it will be shifted to suspension/drivetrain. (I just wanted peoples attention) I have a t45 (tranny) & I want to buy an aluminum driveshaft. Can it be switched over to any different trannys with any modifications? If so what tranny's? (hopefully some tremec's) Can someone find out or a show me a link. I thank you so much! sorry again Brent.
I have an 01GT w/ frpp 3:73's, sportline springs, wms cold-air w/95mm mass-air, (ceramic) BBK equal length headers (ceramic) mac 70mm t. body, trickflow intake plenium, mac pro-chamber, flowmaster catback, Nitto drags, NX N20 150hp jets, & some good predator tuning! Best E.T. 11.79 @ 118.4mph :drive:
[IMG]C:\Documents and Settings\jon.straszewski\Desktop\TOP ****y to bar 020.JPG[/IMG]
Js281GT is offline   Reply With Quote
Old 02-28-2005, 07:25 PM   #2
Bump
Old 02-28-2005, 07:30 PM   #3
Yes. Sometimes the yokes need to be changed.
Laser02 is offline   Reply With Quote
Old 02-28-2005, 07:40 PM   #4
Unless it's a TKO. The U-joints are too big.
Old 02-28-2005, 07:41 PM   #5
Or a T56.
Old 02-28-2005, 08:45 PM   #6
Bane-'s Avatar
buy a cobra
sorry couldnt resist but look at the driveshaft you want, should list the trannys it will fit most ar ethe same length and shouldnt have to big of a problem
Old 02-28-2005, 10:13 PM   #7
you could have your driveshaft made to fit any tranny by having a machine shop add or take off some inches. and also sometimes changing the u joints and yoke. alot of guys that do engine swaps have to do this all the time. im helping a guy right now put a 350 engine into an old nova and we had to get his stock drive shaft cut, the machine shop charged him 70 bucks.
Old 03-01-2005, 10:49 AM   #8
Thanks 232. Why dont you go to the track on april 2nd so I can give you my $5, since you live 20 minutes from me. Can you put my quote up btw? lol So bottom line I should buy one for my t45 & then worry about it later.
Old 03-01-2005, 11:12 AM   #9
Yes. That is why it won't work on the T56... It needs to be trimmed 3/4". Unless it's the TKO, the most you're going to need to do it trim it or swap yokes... With a TKO, the 31 (I think) spline yoke won't fit the u-joint on the smaller driveshaft.
Old 03-01-2005, 12:39 PM   #10
UTGTMustang's Avatar
Region: Utah
Send a message via ICQ to UTGTMustang Send a message via AIM to UTGTMustang
When I got mine and went to put it in, the yoke that came with the Aluminum driveline wouldn't fit into the Tremec. So I had to use the yoke from my car and the aluminum driveline. I was just real careful tearing it apart so I could re-use the new joints.
2003 Silver Metallic GT
Interior: Medium Graphite Leather
http://www.mustangevolution.com/foru...ine=1109135772
BBK LT Headers & X-Pipe, FRPP B Springs, Steeda CAI, Aluminum Driveline, Flowmasters, Chin Spoiler, Magnaflow Stainless Steel Exhaust Tips, 16 Ga Stainless Steel Bumper Inserts, Sequential Turn Signals, 3M Tint
UTGTMustang is offline   Reply With Quote
Old 03-01-2005, 12:51 PM   #11
Danger Dude's Avatar
I have an aluminum drive shaft I will sell you. All you need is to use your front yoke and get new U joints
Old 03-01-2005, 03:09 PM   #12
Can you use it later on a TKO 500 tranny? With what modifications? And all I need is those two things for that driveshaft to fit on my t45? Thanks Danger
Old 03-01-2005, 03:11 PM   #13
Also where can I get the new u joint & how much will they run about?
Old 03-01-2005, 03:43 PM   #14
yes
Old 03-01-2005, 03:45 PM   #15
You can ge new U-joints and any parts store like aytozone, Advance, NAPA or Pepboys
I have started to use NAPA more and more simple because they use very little chinese stuff and they dont have ricer stuff
Old 03-01-2005, 04:37 PM   #16
eh i dont really want the five bucks.
and school and work is getting in the way of me going anywhere.
i cant even get on here much and the new post whores are passing me.
btw, i didnt answer your question for the money, brent pays me a bunch to mod his site.
Old 03-01-2005, 08:19 PM   #17
jimmy_beaner's Avatar
Region: Iowa
my friend works at a place that can make driveshafts however you want them done.... aluminum too, also, he rebuilds rearends... I may get a Ford 9" when I get my Cobra
Old 03-02-2005, 04:02 PM   #18
How much would you sell me the driveshaft for? Is it Ford racing? And for sure it will fit my t45? Thanks!
Old 03-02-2005, 07:13 PM   #19
It is a FMS aluminum Drive shaft 140 + shipping. yes it will use the yoke of whatever tranny you are going to use. What year is the car
Old 03-03-2005, 10:22 AM   #20
It is an early 2001 GT. 99-01.5 Different tranny than 01.5-04
Old 03-03-2005, 10:22 AM   #21
How much do you think shipping will run?
Old 03-03-2005, 10:39 AM   #22
I would imagine around $30-35. It was around 20 shipped to me and they were relatively close
Old 03-03-2005, 11:39 AM   #23
Ok I am getting my two new rims (ebay) & my new drag radials this weekend. I will buy the driveshaft in a couple weeks, is that ok?
Old 03-03-2005, 11:39 AM   #24
So it should fit my early 01?
Old 03-03-2005, 11:40 AM   #25
if the length is right you can swap over the yokes almost alwasy if the size that its accepting was the same that came from it. I am sure they make adaptors or they probably make them all pretty much the same just be prepared that you may run into an issues of meeting em depending on the strenght or the design reguired, i bet ford uses all basically the same.
Old 03-03-2005, 11:47 AM   #26
Now you are starting to scare me. :chin:
Old 03-03-2005, 11:57 AM   #27
yes it will work on your 01. Only the 99+ Cobras has a different Aluminum shaft
Old 03-03-2005, 11:58 AM   #28
I will most likely have it. I removed it from the classifieds area on the forum
Old 03-03-2005, 03:59 PM   #29
K, thanks I will keep you posted.
$125? lol
04:57 PM
