dash lights blow out - Mustang Evolution
Old 06-07-2009, 02:07 PM   #1
ok 98 gt and everytime i turn my lights on i hear a pop in the speakers and the radio shuts down and then restarts but the dash lights do not work. the guages work and everything else and the fuse is not blown.
any help
also it only does the reset thing once now with the fuse still good they still refuse to turn on but the headlights and day time lights turn on fine.
eddie1 is offline   Reply With Quote
Old 06-07-2009, 04:47 PM   #2
OsirisGuy's Avatar
Re: dash lights blow out
Well there is definitely a short.
Do you have an aftermarket radio? If the dimmer switch/wire is hooked up it could explain for the speaker pop and dash fuse blowing.
Not sure about the whole restart thing.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 06-07-2009, 04:56 PM   #3
hmmm ok ill pull out the deck and the radio kinda restarts.....it a 7" in-dash deck and when it shorts i shuts down then starts back up.....thing is the fuse is still good but the lights still won't work.
Old 06-07-2009, 04:59 PM   #4
OsirisGuy's Avatar
This may sound stupid but is the dimmer knob all the way up?
OsirisGuy is right
2002 Mustang GT
Old 06-07-2009, 05:18 PM   #5
haha yea i tried it all it ust popped, restarted the radio and then the lgihts stopped wroking....yet fuse is still intact.
Old 06-07-2009, 07:35 PM   #6
is there any other fusesthat go with the dash lights other than the one 10amp one labeled number 13
Old 06-07-2009, 11:10 PM   #7
OsirisGuy's Avatar
It's very possible that it is another fuse, however it will not solve the problem. You need to start searching the wiring first I'd say.
OsirisGuy is right
2002 Mustang GT
Old 06-08-2009, 06:27 PM   #8
try to turn the knob to make the dome light come on, and then see if your instrument panel lights work then. could be a bad headlight switch, i had the same problem with mine.
96 GT- Who knows what's in it.
Old 06-08-2009, 08:42 PM   #9
now my freaking tail lights don't work they work if the breaks on but if the head lights are on they don't turn on only when you hit the break.......and the day time lgihts no longer work eather......WTF is this only thing that works are the head lights and who knows how long they will last now
Old 06-09-2009, 01:34 AM   #10
check the headlight/dimmer switch, sounds like that went out.
« heads | gears »
how to replace the LED lights in you dash aapierce1990 Mustang Audio & Video 6 06-29-2010 11:18 AM
Tire blow out Scut95 The Bar 7 08-25-2008 11:12 PM
dash lights out after installing aftermarket radio vblic 1996-2004 Mustang GT 3 08-10-2007 05:46 PM
Paypal really does blow Brent The Bar 1 10-24-2006 02:15 PM
My Knee is going to blow up Seph The Bar 26 05-22-2004 08:35 AM
02:40 PM
