supercharger... - Mustang Evolution
Old 06-09-2009, 01:19 PM   #1
supercharger...
question i was told the best way to get power out of a stock 4.6L 2V is a supercharger, im still learning about mods so what is prolly the best one i could do without completly overhauling the whole engine, or do i have to completly overhaul it, i know i do if i wanna up the boost but for about 100hp how much would i have to change? alot of questions but like i said im just getting into the whole mustang mods, ive had my care a year i got a bbk coldair intake n flowmasters n i thought the car was good enough and then... the other day some rice beat me down...badly so i cant have that anymore ...
johnnyc is offline   Reply With Quote
Old 06-09-2009, 01:49 PM   #2
hottcobra's Avatar
Re: supercharger...
this is everything you need to not let that happen again
http://www.lethalperformance.com/96-...-c-464_541_546
Old 06-09-2009, 01:52 PM   #3
Re: supercharger...
how much would it cost me to get that with parts n labor? and where can i find these parts? brothers performance? or is there a better website?
Old 06-09-2009, 01:54 PM   #4
Re: supercharger...
hey just looked at the link will that work in my stock 96 n is there something a lil cheaper like 3000?
Old 06-09-2009, 01:56 PM   #5
hottcobra's Avatar
Re: supercharger...
well you can buy the kit right from that website. and any good shop that you can trust should do it for about a grand
Old 06-09-2009, 01:59 PM   #6
Re: supercharger...
another quick question if i was to but the kit would i need a beefier tranny or should the stock one be alright?
Old 06-09-2009, 02:02 PM   #7
hottcobra's Avatar
Re: supercharger...
just driving the car on the street it should be fine. If you do a lot of racing the car it will one day give up. you will need to upgrade your clutch.
But I wouldn't about upgrading anything until the stock parts give out.
Old 06-09-2009, 02:06 PM   #8
Re: supercharger...
alright well i appreciate ur help man idk if i can afford that but ill deff look into it man...neways take care man thanks again
Old 06-09-2009, 02:09 PM   #9
hottcobra's Avatar
Re: supercharger...
no problem.
and
Old 06-09-2009, 02:38 PM   #10
Re: supercharger...
never do a major mod to a car like a supercharger or turbo charger unless you can afford for the car to break and you can afford to fix it... as its a risk and it puts more stress on the engine.
With that said if you want to go for it a single turbo will cost a bit more but it will make MORE power on LOWER boost. For everything either supercharger or turbocharger depending you may have to upgrade the fuel pump, fuel injectors, have a custom tune, and such. 100 more hp is not that bad as stock they are around 230-245rwhp (99-04s... pre 04s are MUCH worse).
Also if it is a 96-98 it might be best just to upgrade the heads to the 99+ style and you will raise the hp from 215 to 285~
Old 06-09-2009, 06:58 PM   #11
Re: supercharger...
question on that because i was leaning towards the heads more myself would the ford pi heads be just as good because i saw them on jegs and they even had the gasket kit n stuff that i would need. or do you know a better set of heads i could have thrown on that would get me up there..id like to have the car around 300hp it is a 96 with 64000 and i ?have flowmaster n a bbk coldair intake on it. im looking to spend around 2500.any ideas
Old 06-09-2009, 09:04 PM   #12
iwannagofast's Avatar
Re: supercharger...
just supercharge it. That what i did and love it, i put down 301whp on the dyno with 6psi. i'd recommend a stronger clutch, and a short throw shifter. i was street tuning my car after i put on a PI intake and missed 3rd and the shift fork broke cause the trans to be junked. if i would have had the short throw i may have avoided that
iwannagofast is offline   Reply With Quote
Old 06-09-2009, 09:31 PM   #13
MonteCitan's Avatar
Re: supercharger...
May I suggest :
'96-'04 Mustang 4.6 2V 2.1L Supercharger
Great for around town driving, no need to rev it high to get peak power and torque
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-09-2009, 10:02 PM   #14
Re: supercharger...
DAMN! dude 151hp at 9psi!? would i run it at 9psi or 6? i have a short throw (bbk) so im on that lol but the big question is with that supercharger how much is the cost and what else shuold i replace? should i get a new fuel pump and do i need to beef up my tranny?
Old 06-10-2009, 07:10 AM   #15
Re: supercharger...
the 99-04 stock GT heads are considered PI heads, they are going to be cheaper to buy/rebuild/install and bump you up by about 70hp~
Old 08-16-2009, 03:25 AM   #16
Re: supercharger...
i would super charge it if you have the money, i have the procharger kit with a 12lb pulley pushing out 12lbs of boost. My stang put down 425 to the wheels about a year ago. but like SpectorV said dont do it unless you have the money to fix it . im learning the hard way. Im having to either change to a smaller pulley like a 10lb or go with bigger injectors and to get it retuned and tested is going to run me $900 so only do it if you can afford
1995procharged is offline   Reply With Quote
supercharger???? bluestang1724 1979-1995 Mustang GT 21 08-02-2007 08:33 PM
supercharger??? bluestang1724 Pre-2005 V6 Mustang 6 06-11-2007 03:29 PM
SUPERCHARGER! pony rider Pre-2005 V6 Mustang 17 05-30-2007 07:44 AM
Supercharger cms09071987 Pre-2005 V6 Mustang 6 06-26-2005 07:03 PM
gt or supercharger....? chevykiller Pre-2005 V6 Mustang 13 08-14-2004 04:41 PM
02:06 PM
