need info! - Mustang Evolution
Old 06-09-2009, 07:09 PM   #1
need info!
ive gotten some info l8ly from a few guys n ive decided id like to get heads for my 96 4.6 2V, ive gotten alot of support for the pi heads and trick flows but i cant find a place that sells them 4 my car i was wondering if i can get the real deal info on a set of heads that i can put on my car for about 2000, and get the most bang for my buck, n if i could get a lil info on everything it intails like can i just mount the heads or whatelse goes into changing the heads like what else do i need to change with it other than the gaskets n stuff, i know alot of questions but i just got into building my car up n i need the help from some pros, i really apreciate nehelp u guys can send my way ive learned alot already n ive been on the site for 2days u guys are great thanks again...john
johnnyc is offline   Reply With Quote
Old 06-10-2009, 07:11 AM   #2
Re: need info!
You should be able to get a set of PI heads and intakes and basically most everything needed for quite cheap. You just need to buy a 99-04 GT motor and use the stock heads off of it as they are the PI heads. I have never researched this or done this so its best to make sure all 99-04 motors work or which ones dont and such~ overall a junk yard engine that runs shouldnt be much more than 1000~ by the time you figure in rebuilding the heads and putting on better springs and such you shouldnt be in them for to much~ if you can install them yourself thats great as well.
Old 06-10-2009, 07:23 AM   #3
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: need info!
i would try finding a 99-04 cobra (well maybe not the 03/04 cobra...) engine and just swap it, they are sometimess spendy to find... but the extra 2valves might be worth it for future upgrades instead of getting heads now and than doing that later... just a thought
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 06-10-2009, 11:36 AM   #4
Re: need info!
usually 03/04 cobra motors with trans go for 5-7k though (good condition and all that)
Old 06-10-2009, 01:32 PM   #5
Re: need info!
an engine swap sounds good later down the line but i only got 64000 on mine so idk i heard the 4.6 2v is pretty good at taking a lickin, regardless i think the pi heads and an upper/lower intake would prolly be the wayto go 4 now, does ford make an upper/ lower intake that will just bolt on my car or is there a better aftermarket one?
Looking for info Firewolf 1979-1995 Mustang GT 7 10-13-2009 08:59 AM
need some Info fried_rice101 1979-1995 Mustang GT 6 12-02-2007 08:57 PM
need some info? ryanxup Pre-2005 V6 Mustang 2 11-22-2006 09:43 PM
info bmw ponyman Pre-2005 V6 Mustang 3 09-29-2006 09:35 PM
I would like some info please Blue GT 5.O The Bar 8 04-01-2004 08:27 PM
05:28 PM
