Air Conditioning problem - 96 Mustang V6 - Mustang Evolution
Old 06-11-2009, 10:40 AM   #1
Hi, new user here. I have a 96 Mustang V6 automatic. It's summer, and my air conditioning compressor clutch will not kick in. I've checked the fuses in two places, and the AC clutch coil is supposed to work off the same fuses as the clock illumination, which works fine. I know the compressor is good, because I hot-wired it to the battery, and it works, blowing very cold air. I hate to leave it hot-wired, because it has to be disconnected from the battery before you shut off the motor or smoke comes out of the wire. Any ideas what might be causing the clutch not to engage, other than fuses?
Warm in West Virginia
WVKarenC is offline   Reply With Quote
Old 06-11-2009, 10:56 AM   #2
2007STANG's Avatar
Region: West Virgina
Re: Air Conditioning problem - 96 Mustang V6
There is a low pressure switch if the freon is low it will not let the clutch engage i have fixed the problem by going to auto zone get a can of 134a and charge hose and install on the low side while installing the clutch will start working. the correct way to do it is to have a set of gauges and read the pressures and adjust as needed. (they make dye so you can find the leak) i could go on an on
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 06-11-2009, 03:50 PM   #3
Thanks for the help, but been there, done that. I put in the freon, and thought the clutch would kick in during the process, but it didn't. I think it's an issue of the ac compressor clutch not getting juice, since it works when it's hotwired directly to the battery. Does this make sense? Any other ideas?
Old 06-12-2009, 09:16 AM   #4
2007STANG's Avatar
the clutch is powered through the low pressure switch jumper the switch and see if the clutch engages
Old 06-12-2009, 09:54 AM   #5
Thanks for the answer. Just to clarify, is the low pressure switch the electrical connector on the compressor? I've hotwired from the compressor to the hot battery terminal and everything works the way it's supposed to. Can you tell me where the switch is located, or what it looks like? Thanks again.
Still warm
Old 06-12-2009, 10:17 AM   #6
2007STANG's Avatar
its on the tubing going back to the reciever you will see two wires coming out there are two, high pressure on the smaller tubing and the low pressure on the bigger tubing
Old 06-12-2009, 03:12 PM   #7
rydog's Avatar
Send a message via MSN to rydog
Its called a clutch cycle swith and its about $15 at advance and its what tell the clutch to engauge it went out on mine simple 15 dollar fix.
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 06-12-2009, 05:10 PM   #8
Thanks rydog! I'm headed to Advance. I can feel the cool air already.
Old 06-15-2009, 12:42 AM   #9
2007STANG's Avatar
well did it fix it
96 3.8l V6 - Air Conditioning gary2381 Pre-2005 V6 Mustang 1 06-24-2010 03:35 PM
Air vent problem.Help! fordguy5.0 Pre-2005 V6 Mustang 2 12-03-2007 10:58 AM
Air Conditioning Q wrecked2001 1996-2004 Mustang GT 9 10-28-2006 05:08 AM
12:21 AM
