Question about short headers - Mustang Evolution
Old 06-13-2009, 01:40 PM   #1
Region: Nevada
I've heard on bolt on GT's shorty headers add almost next to nothing but how much would they help on a supercharged GT? How much HP/TQ (approximately) would they add?
chris098 is offline   Reply With Quote
Old 06-14-2009, 09:42 PM   #2
Re: Question about short headers
are these the frpp shorties? i have seen a write up on these headers, they added near 10 with forced induction. the way to go would be long tubes if u can afford them, usually u can find used sets for a decent price.
96 GT- Who knows what's in it.
Old 06-15-2009, 08:03 PM   #3
Region: Nevada
My only concern about longtubes is im not sure if I would pass a smog with them. What about mid lengths? Do they produce similar power numbers to longtubes?
Old 06-15-2009, 09:43 PM   #4
its pretty close as for gains. i assume they check emissions where you are at, you will also have to retain a catted midpipe in order to pass.
Old 06-16-2009, 07:09 AM   #5
long tubes should pass as you can get a long tube catted pipe but they are quite expensive, do check local laws first though
Old 06-16-2009, 07:52 AM   #6
slostang's Avatar
IMO if you are gonna buy headers just get the longtubes. I had shorties on my car and they made almost no difference at all. You will more than likely see the most gains with a set of longtubes on a forced induction setup. Most longtubes are 50 state legal as long as you are running cats.
Hi Rob
slostang is offline   Reply With Quote
Old 06-16-2009, 08:00 AM   #7
longtubes will be the best.
tvs supercharger,20 lbs of boost,cti stepped header, cti 3" catless dp,cti 3" catback,79# injectors,ls4 tb,rebel 3" cai, cx raceing heat exchanger ,billet rotated tranny mounts,dss stg 2 axles,spec 3 plus clutch,spec alum flywheel,steel crank,steel rods,hyper. pistons,4.05 1st gear,posi diff.. tuned by auto motion .next week meth and more boost.
fast cobalt is offline   Reply With Quote
Old 06-16-2009, 08:44 AM   #8
Herbstang's Avatar
This may help Short & Long-Tube Headers Test - 5.0 Mustang & Super Fords Magazine
http://www.mustangevolution.com/forum/t25082/
headers question? need help DEG Pre-2005 V6 Mustang 19 11-12-2009 12:17 PM
Short Shifter Question SaturnMan8227 Pre-2005 V6 Mustang 5 09-21-2008 10:25 PM
which short throw to go with? kcfan_2004 General Mustang Discussion 6 09-12-2008 11:34 AM
short vs. long a00v6stang Pre-2005 V6 Mustang 16 01-02-2006 04:40 PM
Short shifter 19ClearCobra96 1996-2004 Mustang GT 12 01-05-2005 10:23 AM
10:21 PM
