| engine coolant drain plugs
engine drain plugs - where are they?
back by the oil drain or in front by the steering mechanism?
i pulled a bolt on the driver's side on the lower side of the engine block way back by the oil drain plug (above it) and nothing came out. i either did a perfect drain job, or this was not the plug. the one on the other side was pretty impossible to reach with a socket or wrench. there are also two bolts toward the front above the steering system, but i also couldn't get a tool on them. these are metal bolts and not plastic, right? i'm either looking right at them, or they aren't there. once again, haynes is no help on this one.
don't buy haynes.
i'm all drained, flushed, t-stat swapped and ready for fill.
want to make sure i've done it all before filling it back up.
__________________ |
