newbie here need help - Mustang Evolution
Old 03-22-2005, 02:07 PM   #1
well i like to say hello first to everyone.
ok here is the deal i have a 2001 mustang gt conv.
it has underdrive pullys and a hypertech program. i purchased a bbk throttlebody and a light bar the other day. here is the problem. i installed the throttlebody and took the car for a ride down the road. when i put it to the floor it boggs down any ideas why it boggs. car has been sitting in the garage all winter if that matters.
thanks 4 the help
jim
jrs01gt is offline   Reply With Quote
Old 03-22-2005, 02:18 PM   #2
Swapping out the throttle body could be causing the car to run real lean/rich. This program you have installed, does it take into account the new TB? I know with my car, if I change anything with the air intake or exhaust, I need to get the Air Fuel ratio rechecked and/or corrected. A throttle body change could have a huge difference on how much air you bring in. If the car doesn't know what to do with that much air, it could become unhappy.
By the way, I am by no means a motor head. I am just stating things I have learned since buying my cobra.
Old 03-22-2005, 02:32 PM   #3
i forgot to add i added a cold air intake also.
the program i have is a hand held power programer. i can't really change too much. i got it to change my speedo for the 3.73 gear i installed.
Old 03-22-2005, 02:34 PM   #4
The throttle body sounds like your problem man...install your stock one and see if it still does it.
Old 03-22-2005, 02:37 PM   #5
with the stock throttlebody it is fine. i wonder if the car has to adapte to the new part i installed. or i wonder if i need to buy something else. this thin wasn't cheap. i really don't want to use it 4 a paper weight
Old 03-22-2005, 02:46 PM   #6
You should be able to get a custom tune for a hypertec tuner (I assume this works like SCT and Diablo). They can add more fuel to your tune and that will fix things. Or, you can get to a dyno shop and get it dyno tuned where they will add more fuel to the mix and you should be good to go. A dyno tune session here runs about $100 for 3 pulls plus a little more for the actually tuning.
If anyone else knows about hypertec and how that speal works, chime in.
Old 03-22-2005, 02:54 PM   #7
i'll have to try to find my paperwork on my hypertech and see if says anything about getting it updated. thanks for the fast replys.
ps: installing a light bar in a mustang (pain in the rear)
i'll put up some pics of it in a couple of days when its done.
Newbie from NJ rkaiser New Member Introductions & Greetings 14 07-30-2010 08:55 AM
NEWBIE 2quick New Member Introductions & Greetings 14 11-12-2007 09:02 PM
Newbie saying hi orange05tj New Member Introductions & Greetings 18 08-15-2007 06:19 PM
02 Newbie chertzfelt New Member Introductions & Greetings 9 07-18-2007 05:16 PM
Newbie SpeedNStylez New Member Introductions & Greetings 15 07-09-2007 12:00 PM
12:28 PM
