Short Vs Long Block - Mustang Evolution
Old 07-06-2009, 04:20 PM   #1
SVTCOBRA's Avatar
Short Vs Long Block
I was woundering what the difference is between a Short block and a long block? What type (Short or Long) of block is in the 2003/2004 Cobras and Mach 1s? Which one is better for drag racing?
SVTCOBRA is offline   Reply With Quote
Old 07-06-2009, 04:25 PM   #2
Re: Short Vs Long Block
Short block = just the block, and rotating assembly (pistons, crank, etc).
Long block = Short block plus oil pan, heads, and sometimes upper and lower intakes.
The 03/04 cobras and mach 1's have the same block, but have different internals and top end components...ie cams, head profiles, and intakes.
The 03/04 cobra short block would be better for drag racing because it is forged already. The long block would obviously also be better as it would have the forged internals as well as the supercharger. lol
Old 07-06-2009, 04:34 PM   #3
SVTCOBRA's Avatar
Ok cause Ive been looking at buying a used high milage GT and building up a MMR stroker block. So the only difference is the stuff on it alright.
Old 07-06-2009, 04:39 PM   #4
hottcobra's Avatar
look at it like this.
a short block is half of a complete engine
http://www.livernoismotorsports.com/...g-37-large.jpg
a long block is a complete engine
http://www.livernoismotorsports.com/...1740-large.jpg
Old 07-07-2009, 10:26 AM   #5
SVTCOBRA's Avatar
So if Im going for more of a Kyle custom engine go short block, or long block just in case I screw something up? What would you guys go with?
Old 07-07-2009, 10:34 AM   #6
If money isn't an option, go long block. Then you can get custom cams and everything that you want all at once assembled.
If you are doing this on a budget, you could get the short block and reuse your top end. However, the only reason to do this would be if you were seeing issues with your current engine since if you reuse your stock stuff, the short block really won't be giving you anything.
If you plan on sending your stock heads off to get ported/polished/cam swaps/etc, and your upper and/or lower intake to get ported, then you could save some money over getting all new stuff with the long block.
So, if you want the most out of your new motor, you either have to get the long block with all new high performance stuff...or you will need to take your stock stuff and get it all worked out to higher performance specs and just get the short block.
If you won't be doing the work yourself, it would be best to get the long block as you will save yourself a good bit in labor you would accrue in the tear down and re-assembly of your engine. A long block just drops in...less labor.
Old 07-07-2009, 11:59 AM   #7
SVTCOBRA's Avatar
Ok yeah,
what style year do yall like for drag racing?
Old 07-07-2009, 12:18 PM   #8
What style/year of what do we like for drag racing?
Old 07-07-2009, 03:53 PM   #9
SVTCOBRA's Avatar
Mustang body of course. I know alot of people like the foxbodies cause they are light but I want to be different.
Old 07-07-2009, 08:29 PM   #10
upton7's Avatar
my favorite model is 99-04 thats what i'm goin with cuz i already have one. Its basically whatever you like when it comes to the actual car. Most people get foxes cuz of the 5.0
Old 07-07-2009, 09:29 PM   #11
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
i personally like the 94-98 body the best, 99-04 like upton said is a good body as well. You'll just have to go through extra measures to lighten the crap outa them... foxes were the one of the lightest mustangs, and they are one of the cheapest and they fit pretty much any engine supposedly. Just remember its all personal preference.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-07-2009, 10:18 PM   #12
upton7's Avatar
+1 exactly if u get a body u like you'll be much more happy with ur finished project
Old 07-08-2009, 10:53 AM   #13
SVTCOBRA's Avatar
I dont care what it looks like as long as it can go down the 1/4 mile in low tens or high nines. THen Ill be happy.I just like another opinion.
Old 07-08-2009, 10:57 AM   #14
Region: Oregon
if you really don't care i would say a fox body just cause they are lighter :S personally i don't like the body style that much, but you can make them extremely fast and it will be the cheapest body to find
Old 07-08-2009, 02:38 PM   #15
SVTCOBRA's Avatar
I was looking more for a 1999-2004 style, but Im open to any style.But Im waiting for my neighbor to put his 1979 Mustang GT with T-Tops up for sale so I can restore it.
Old 07-08-2009, 08:26 PM   #16
upton7's Avatar
you can't get a 99-04 with the 4.6 below ten seconds. Unless you got a **** ton of money and skill
Old 07-08-2009, 09:19 PM   #17
Otlaw80's Avatar
79 with T-tops? was it custom done? T-top wasn't an option on the fox till 81 or 82 i believe.
None the less thats the only way i like fox bodies but they are weaker structuraly and will need reinforcing.
Old 07-08-2009, 09:34 PM   #18
Depends on your definition of **** ton of money....it can be done with an 03/04 cobra for around 5k and race gas.
Old 07-09-2009, 09:25 AM   #19
SVTCOBRA's Avatar
My bad I meant 1985 not 1979(I was reading a article in MM&FF about a 1979 hot rod). I do know that any convertiable, T-Tops, and Targa Top will be weaker structuraly but I was looking to just restore it to factory spec. But yeah its a 1985 not a 1979.
Old 07-09-2009, 09:28 AM   #20
SVTCOBRA's Avatar
No man I was looking at a custom built 5.4 or 5.0 4v DOHC to put into a 1999-2004 body.
short block iwannagofast 1996-2004 Mustang GT 5 08-04-2009 03:44 PM
331 short block juced302 1979-1995 Mustang GT 1 04-30-2009 01:25 PM
DSS short block iwannagofast General Mustang Discussion 1 01-07-2008 03:59 PM
short vs. long a00v6stang Pre-2005 V6 Mustang 16 01-02-2006 04:40 PM
09:49 AM
