brake binding issue needs fixing fast!!!!! - Mustang Evolution
Old 07-10-2009, 07:59 PM   #1
Exclamation brake binding issue needs fixing fast!!!!!
i just purchased a 2000 GT and it has a few things that need repaired. First thing I want to tackle is the brake pedal that is binding when the pedal gets close to full brake. In speaking to a repair shop they seem to think it is the hydrobost or power steering pump. I'm leaning to the hydrobost. But I'm also wondering if it could be one of the brake caliper pistons. Has anyone every had this problem before or any suggestions to confirm problem before I purchase a 280.00 part and tear everything apart to find out that it's something else. Any insight would help.
jkaminski24 is offline   Reply With Quote
Old 07-10-2009, 08:22 PM   #2
2007STANG's Avatar
Region: West Virgina
Re: brake binding issue needs fixing fast!!!!!
caliper pistons stuck would lock/drag your breaks you would fell like the car is being held back when you say "brake pedal that is binding when the pedal gets close to full brake" is the brake staying down or is there a place where it is sticking/catching Does it have anti lock brakes
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 07-10-2009, 09:56 PM   #3
Exclamation Re: brake binding issue needs fixing fast!!!!!
Not caliper pistons, no fluid leaking. The pedal does not stay down. It feels like the pedal is hitting a bump. I belive the shaft that runs through the firewall is binding in the booster.
I was thinking today that maybe I need to bleed the brakes one more time. But I ruled that out again today because if air was in the lines it would be a soft feeling from the start. Or am I wrong.
Old 07-10-2009, 11:13 PM   #4
2007STANG's Avatar
Yea if there was air the pedal would go way down and feel real soft do you have anti lock brakes have you ever felt that how the pedal jumps real quick is that the feeling if not then i would say the booster
Old 07-10-2009, 11:28 PM   #5
im pretty sure i have anti lock brakes but i dont think thats the problem.
but it is like a jump so i could be wrong.
when im just sitting in the car and i press down hard on the breaks abt 3/4 of the way down its a hard fast jump. It almost feels like the pedal doesnt want to go any further but it is able to be forced further.
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
and a 18 year old adrenaline junkie :burnout:
Old 07-10-2009, 11:44 PM   #6
2007STANG's Avatar
try doing it in park with the engine running if it is a machical problem you should still feel it
Old 07-10-2009, 11:50 PM   #7
yea i still feel it in park with the engine on.
do you have any idea what it could be????
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Old 07-11-2009, 12:17 AM   #8
2007STANG's Avatar
my best gess is the Booster cyclinder (I've always called it the slave cyclinder) on your brake pedal you will see a rod going through the fire wall the cyclinder is on the wall in the engine bay I have had a floor mat cause that problem before
Old 07-11-2009, 10:34 PM   #9
DarkShadows's Avatar
my car does that. and does a few other stangs. i never knew it was an issue. stops fine for me.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 07-11-2009, 11:02 PM   #10
yea mine stops fine its just my stupid parents think that its going to kill me but whatever
00 GT 5spd
flowmasters exhaust
cold air intake
3.73 gears
Need Help!! Center Console and Parking brake issue... Frogleg 1996-2004 Mustang GT 5 04-15-2009 10:10 AM
brake line issue... jimmy_beaner 1996-2004 Mustang GT 0 03-24-2008 08:11 PM
Im fixing to be out of the area until thursday SpectorV The Bar 7 07-08-2005 11:38 AM
Fixing Yellow Headlights Dvelup Mustang Audio & Video 3 07-16-2004 06:18 PM
12:59 AM
