A lil exhuast problem - Mustang Evolution
Old 07-11-2009, 11:29 AM   #1
upton7's Avatar
When i first got my car there was a rattle in the back i fixed it when i put my x pipe on. What happened was where the pipe goes over the rear end it had leaned against the unibody and when i take off at low rpms or go over bumps it rattles and its annoying. It fell over again yesterday can i just put it back and then put some sort of metal strap around it and screw it to the unibody? Or does someone have a better idea.
Old 07-11-2009, 02:39 PM   #2
RyansQuick6's Avatar
Re: A lil exhuast problem
You just need to loosen the exhaust clamps and adjust it.
RyansQuick6 is offline   Reply With Quote
Old 07-11-2009, 03:49 PM   #3
upton7's Avatar
already did twice and it fell to the side both times
Old 07-11-2009, 04:44 PM   #4
Otlaw80's Avatar
tighten the clamp more. I've never seen a pipe move once it was clamped down.
Old 07-11-2009, 04:49 PM   #5
upton7's Avatar
i'm not kiddin i got it tighter than a virgins *****
Old 07-11-2009, 05:28 PM   #6
Otlaw80's Avatar
lmao. is it stainless? do you have access to air and an impact gun?
Old 07-12-2009, 11:59 PM   #7
upton7's Avatar
no and no i think i'll just adjust it again then if it falls again i'll put sumtin around it
Old 07-13-2009, 07:41 AM   #8
take a metal clamp like the CAI uses to connect to the throttle body and get something rubber that slides onto it and then clamp it around the exhaust the rubber will hit the unibody and keep the metal/metal contact from happening. OR you can get a shop to adjust it so it doesnt hit.
Old 07-13-2009, 10:04 PM   #9
upton7's Avatar
i think i will try the rubber idea thanks man
the best exhuast system and headers ? MaKaVeLi 1996-2004 Mustang GT 6 10-31-2006 05:50 PM
new exhuast bosscityboy86 1996-2004 Mustang GT 0 09-10-2006 07:09 PM
Side exhuast danstang Pre-2005 V6 Mustang 3 07-20-2005 02:52 PM
98 v6 exhuast options XxELeMeNt92 Pre-2005 V6 Mustang 4 09-21-2004 08:12 AM
Flowmaster Exhuast 02MineralGray Pre-2005 V6 Mustang 2 08-31-2003 08:52 AM
11:07 PM
