Clutch smell issue - Mustang Evolution
Old 07-13-2009, 11:37 PM   #1
Clutch smell issue
Ok so I was on this very steep hill and I stalled. There were a bunch of cars behind me and honking, I usually don't stall it was just that I was listening to music and lost focus, so i paniced and tried to get off of 1st gear by letting off the clutch more than usual and I guess i gave it TOO MUCH GAS and smoke started coming out and i smelled a burning smell by my clutch. Now when I drive I feel like it takes longer for the car to engage and move,
so did i just completely destroy my clutch!? Some people told me the smell will go away and its just that you damaged your clutch, but its not completely worn out.
Rich_Guy is offline   Reply With Quote
Old 07-13-2009, 11:54 PM   #2
Re: Clutch smell issue
It should be ok. Have you let it cool all the way down and drive normal again? It shouldn't be damaged too terribly.
I smoked the hell out of my stock clutch a few weeks before pulling it out and you can't point out a hot spot on this thing. They're tougher than you think.
Old 07-14-2009, 12:39 AM   #3
Idk man im ****ed if the clutch is gone b.c im broke..
well i let it sit for 1 hr and i took it around the block and i noticed that the smell is not as strong, but when i try to get going in 1st, the engaging part is taking longer to "hook up".. i hope this will go away, i dont like holding my clutch too long.............
Old 07-14-2009, 12:48 AM   #4
the clutch is still stiff oh btw its only 1st gear... all the other gears are acting normal.. but the engaging part for 1st is taking way to long to hook up... i hope it "cools" down and everything will be okay
Old 07-14-2009, 08:26 AM   #5
if it only happens in a given gear its probably not the clutch but the trans. if you slipped your clutch a little much it may have glazed it some, it might wear out over time~ as long as its working dont worry so much about it.
Old 07-14-2009, 01:03 PM   #6
oh ok, i just woke up and its been well over 10 hours since i drove my car. I will have to drive it again and see if 1st gear is still taking as long as it was to hook up.
Old 07-14-2009, 01:08 PM   #7
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
just pretend you didn't do anything and just drive it normal for a week and see how it does...
i was on a very steep hill with my little protege and did the same thing trying to not role back, clutch smelled very bad, but i drove it back down the same hill after about 20 min of cool down and about 5-10 miles back home, and it was fine. that clutch still works to this day (that was like 3 yrs or so ago) and taught my wife how to drive a manual with it, still no problems.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-14-2009, 10:56 PM   #8
Blogger
Blogger
rickf73's Avatar
Send a message via MSN to rickf73 Send a message via Skype™ to rickf73
Stalling is something I have done every few days. I've only had my car a few weeks but I have driven everything from imports to 18 wheelers and have never had this problem. I also have a '87 F-150 4 speed and have never had this happen. Guess it just takes time to get used to this car. Maybe I need to learn to drive all over again.
rickf73 is offline   Reply With Quote
2000 V6 clutch/shifting issue audio75 Pre-2005 V6 Mustang 10 08-01-2010 12:41 AM
Stop/go traffic = smell = clutch? RedFire2006 2005-2010 Mustang GT 8 12-21-2009 09:59 AM
Whats that Smell? Kyle The Bar 6 07-12-2005 05:25 PM
Antifreeze smell? steedav6builder Pre-2005 V6 Mustang 6 07-15-2004 11:30 PM
clutch issue for the 56# time lol SpectorV Pre-2005 V6 Mustang 1 05-12-2003 08:00 PM
01:36 AM
