Lowering my 04 GT - Mustang Evolution
Old 07-14-2009, 09:17 AM   #1
Lowering my 04 GT
I'm trying to lower my Mustang and was wondering how bad of a ride it would be if I just used Eibach springs and my stock shocks? Or is that even possible?
Talon is offline   Reply With Quote
Old 07-14-2009, 09:32 AM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: Lowering my 04 GT
it will wear your shocks and struts out a lot faster if you don't replace them. Do it the right way first
Old 07-14-2009, 09:47 AM   #3
DarkShadows's Avatar
What kind of eibach springs?
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 07-14-2009, 11:18 AM   #4
I was thinking of going with the sportline because it's lower than the others
were there showing 1.5 the sportline says 2.0 in front and 1.8 in the rear.
What else besides the springs do I need. It's to be driven back and forth to work.
Old 07-14-2009, 11:34 AM   #5
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
CC plates, i heard maximum motorsports (MM) sells really good ones, i personally haven't used them yet.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-14-2009, 11:35 AM   #6
prokit would be ideal if you wanted to keep you stock shocks. i rode around for about 8 months with the prokit in and stock shocks with no problem, and the aligment shop was able to ge my car back into spec with out camber caster plates. if you plan on going lower thou then you will need camber caster plates and aftermarket performance shocks.
Old 07-14-2009, 03:22 PM   #7
eibach generally has softer spring rates, but you need to know for sure. Your stock rates are around 400 front 250 rear
Old 07-15-2009, 12:51 PM   #8
Has anyone heard of gabreil shocks or
vogtland springs? If so good or bad?
Old 07-15-2009, 01:06 PM   #9
I Dont know about on stangs but when i was in the vw world people had mixed reviews about the vogtland springs. as far as gabreil shocks i dont think they make a aftermarket performance shock.
Old 07-15-2009, 01:55 PM   #10
Just wanted to say thanks to everyone for the feedback. its helped alot.
Old 07-15-2009, 01:58 PM   #11
never heard of either
Old 07-15-2009, 02:45 PM   #12
pretty sure they sell gabreil at autozone for oe replacement shocks and ive only seen that vogtland springs around the euro crowd
Old 07-15-2009, 06:46 PM   #13
Sorry I keep bothering everyone but I just want to get it right. What
if got H&R springs and went with kyb shocks and struts or would kokico
blues or illumina work?
Old 07-15-2009, 08:02 PM   #14
which h&r springs. and bot toicko and kyb would be fine.
Lowering my 04... 04SonicBlueGT 1996-2004 Mustang GT 22 10-23-2009 12:31 PM
Lowering?? Gt.Vert 1996-2004 Mustang GT 9 10-12-2009 07:12 AM
lowering? 96cobra 1996-2004 Mustang GT 17 04-08-2009 11:04 AM
lowering? Kryptonite Mustang Audio & Video 6 10-23-2006 08:15 PM
Lowering? 19ClearCobra96 1996-2004 Mustang GT 14 05-16-2005 06:54 PM
04:44 AM
