Too much trouble? - Mustang Evolution
Old 07-14-2009, 07:16 PM   #1
upton7's Avatar
Too much trouble?
I bought a longblock for 200 bucks. There is a possiblity of the block being cracked if so i will get my money back. What all would it take to put a 5.0 in the car. I know I'll need a new bellhousing but what else would neet to be done? Its a 2002 gt 5 speed.
Old 07-14-2009, 07:43 PM   #2
hottcobra's Avatar
Re: Too much trouble?
why would you want to backwards?
Old 07-14-2009, 11:41 PM   #3
upton7's Avatar
lookin for power mainly. But i started this engine while it was in the car and u can hear a lil tick when it starts. And the guy said when he take out the dipstick after it had been runnin smoke came out which probably means there is a bad piston ring. But after start up it ran ok. What do u think the chances are of the block being cracked
Old 07-15-2009, 12:53 AM   #4
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
i wouldn't guess the block to be cracked, probably a gasket or ring, i'm guessing you'll need a new k-member (not 100% sure which part that is... but on the 94-98 it is different from the 5.0 to the 4.6, and i don't know which the 3.8 uses...) depending what comes on the engine you'll be looking at all of your efi stuff unless your going with a carb, you'll need a 5.0 comp (not really all that hard to find...)
did the block have any power adders on it? i don't really wanna say "oh it will be ok, just use it" cause i don't know the history of the engine. what year car was this in?
you might need new springs cause of the weight difference (you have the v6 correct?)
new radiator hoses... probably not the most expensive part on the list, but you'll need different ones. I'm just trying to think of anything else different, ill probably remember a little later on.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-15-2009, 08:31 PM   #5
upton7's Avatar
sorry to waste time but i'm not gettin in now i got my engine and there was a small crack but it wasn't in the cylinder or a place that mattered
So...how much trouble am I going to get into? lowflyn The Bar 12 04-14-2009 06:33 PM
Transmission trouble chemimblc 1979-1995 Mustang GT 32 11-01-2007 04:59 PM
Reporter In Trouble Brent The Bar 6 07-11-2007 05:22 PM
Car Trouble megax29 Pre-2005 V6 Mustang 8 01-07-2007 06:31 PM
Looks Like some of us are going to be in trouble!! ComputerGuy The Bar 23 01-16-2006 08:49 AM
12:00 PM
