2000 mustang gt conv. want to modd dont knw where to start - Mustang Evolution
Old 07-16-2009, 10:49 AM   #1
I have a 2000 gt conv. Manual trans. Been wanting to modd it and literally dont know where to start.... Im thinking the tranny because i have had to work on it and replace the clutch atleast twice. Any advice?
luvrobeer is offline   Reply With Quote
Old 07-16-2009, 10:59 AM   #2
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: 2000 mustang gt conv. want to modd dont knw where to start
really depends on what you want to do with the car, most people will probably say gears since this will make your current hp more noticeable...
another first mod would be exhaust, unless your really really like you stock setup.
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-16-2009, 11:01 AM   #3
exhaust since you get sound, looks, and a little power. NO mustang is right without a good exhaust
Old 07-16-2009, 02:33 PM   #4
exhaust is definitely needed, i recommend 40 series muffler it sounds like a beast if you add that on
second if i were you i would put in a after market cold air intake
Rich_Guy is offline   Reply With Quote
Old 07-16-2009, 05:08 PM   #5
SaleenFiend's Avatar
Exhaust, CAI, Short Throw, Gears.... normal tidbits that help you get going...
Old 07-17-2009, 06:17 PM   #6
ok cool... im for all of that stuff. Lol what ive been thinking is the exhaust then cold air intake. follwed by the transmission like a stage 3 clutch and working up from there gears a whole new fly wheel and drive shaft to cope with the added power short shift clutch, slotted rotors and other stuff. what about super chargers? are they worth it? or is it something to get if I just want to show off once in awhile and waste gas?
Old 07-19-2009, 10:52 AM   #7
i agree w/ exhaust but dont go flowmaster. too much drone. go bassani or slp or even magnaflow
NickPic is offline   Reply With Quote
Old 07-19-2009, 11:17 PM   #8
intake elbow, TB, gears, nitrous or any forced induction, long tubes, x or h pipe, good catback system like magnaflow, bassani, borla, etc...
sooo many routes to go
iamdat is offline   Reply With Quote
Old 07-20-2009, 12:54 AM   #9
Region: Oregon
i don't think you'll need a new clutch till you start making some good numbers... and i think the drive shaft will handle a good amount of power. If your looking at trying to save some rotating mass, an aluminum drive shaft would be nice, could also go with 2 piece rotors since your looking at getting slotted ones anyway. Than some good looking light rims (all of this weight reduction will not only be less your engine has to carry, its less your engine has to turn, same concept as underdrive pulleys in a way) I would go with a findaza (sp?) flywheel, they have a replaceable wear area, so you just replace that one strip instead of the whole thing...
EDIT: also superchargers are well worth it if you can afford them, would probably be best to get some supporting mods to go with it,also a really good tune would help it last a really long time and be a lot of fun.
2000 mustang
Push to start for a 2000 blue-saleen Mustang Audio & Video 15 09-10-2009 10:33 AM
ABS Light On 2000 Mustang GT Conv Hotrod316 1996-2004 Mustang GT 3 06-30-2009 11:00 AM
ABS Light On 2000 Mustang GT Conv Hotrod316 1996-2004 Mustang GT 0 06-30-2009 07:59 AM
2000 Mustang V-8 GT Automatic Convertable will not start thechef 1996-2004 Mustang GT 1 04-18-2009 02:36 PM
11:14 PM
