Short Throws - Mustang Evolution
Old 07-16-2009, 03:18 PM   #1
04_GT's Avatar
Short Throws
Im looking at getting a short throw I found the Steeda Tri-Ax TR-3650. I was wondering if anyone has tried it or knows anything about it.
04_GT is offline   Reply With Quote
Old 07-16-2009, 03:22 PM   #2
Re: Short Throws
It's not bad, I had a triax in my GT. Look into an MGW though....you won't regret it. MGW LTD., INC. - CNC Machined and Turned Parts. Accessories for the Corvette, Mustang, and Viper
Old 07-16-2009, 03:46 PM   #3
OsirisGuy's Avatar
Re: Short Throws
I have a Pro 5.0 in my '02 and it is quite nice. All my gears are right there and it's not a far reach at all. The arm goes straight up and doesn't bend towards like the stock one. I rarely (maybe twice) miss third gear. This is also my first manual car.
While the Pro 5.0 is nice I've heard nothing but good things about MGW, just like PureVenom mentions. I'm hoping to pick one up soon.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 07-16-2009, 04:53 PM   #4
DarkShadows's Avatar
Re: Short Throws
mgw is great for our cars, i had a pro5.0 im my 04 before and i didnt like it at all, switched to mgw and never looked back.
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 07-16-2009, 05:00 PM   #5
SaleenFiend's Avatar
Re: Short Throws
I had the UPR Blue thunder and Loved it in my T-3650! MGW is great also! Just take your pick, I'm sure you'll be satisfied!
Old 07-17-2009, 12:39 AM   #6
Re: Short Throws
hm im going to get a MGW shift knob then.. everyone on here says its good and the stock shifter knob is real loose and too old..
if i change the shift knob do you need to change everything else?
Rich_Guy is offline   Reply With Quote
Old 07-17-2009, 01:24 AM   #7
OsirisGuy's Avatar
Re: Short Throws
Yeah the shifter is not just a knob, It's the whole piece.
Check out MGW LTD., INC. - CNC Machined and Turned Parts. Accessories for the Corvette, Mustang, and Viper.
It's an arm and a base which bolts in right into the top of the transmission.
The install for it is very straight forward. At least for 94-04. The trim around shifter pops right up giving you access to the tunnel. Four bolts come out which holds in the dust boot and covering. After this you will see the transmission top and another four bolts. Those four bolts come up to reveal the inside of the transmission. Remove the whole arm shifter and clean the top of the transmission of the sealant gunk being careful not to get any pieces inside. Place a new bead of usually RTV sealant around the base of the transmission and install the new shifter.
MGW, I hear, sends a wealth of information on the install plus all necessary hardware and sealant to get the job done. In fact the install also come on a CD and I hear guys bring their laptops out to their garage, sit and watch it and go along with it during the install.
Foxbody cars are the same I believe except it's a little harder to get to the transmission tunnel through the center console. However I am not sure MGW manufacture's a shifter for the foxbodys. They do have it for T45/T5 transmissions so I assume it should still work.
For the new body styles (S197) I hear the install is a tad more complicated and a little more involved only because a few links must be disconnected and you have to get underneath the car.
OsirisGuy is right
2002 Mustang GT
Old 07-17-2009, 08:35 AM   #8
Re: Short Throws
No, you can just swap out the shift knob. It will fit the stock shift handle. It also has a screw in the side that lets you set the knob any angle you want it so you don't have to screw it all the way down and have it at the wrong angle.
Old 07-17-2009, 08:41 AM   #9
Re: Short Throws
I helped my friend with a 2008 GT install a MGW shifter
it came with:
shifter and all parts needed individually wrapped AND labeled as to exactly what they were.
Full printed instructions in GREAT detail
A freaking VIDEO of the installation on CD
dynomat sound deadening with a foam sound deadening pad
I was very impressed with the lengths they went to, top notch quality.
On a 99-04 you wont get the dynomat and pad as you dont need it.
I had a steeda shifter and now when going back to a car that has steeda vs mgw... steeda is VERY far to the right (due to the adjustment ability of the mgw) and makes MUCH more noise.
basically if you want the best its mgw for all around, pro 5.0 is nice as well but a little to short for daily driving.
Old 07-17-2009, 08:42 AM   #10
Re: Short Throws
if you get a shift knob that has the same thread pattern as your stock handle or what ever handle you have then you will not have to change anything out to use it
Old 07-17-2009, 10:18 AM   #11
Herbstang's Avatar
Re: Short Throws
The tri-x is alright I had to modified mine to get it closer to the drivers side and add a little height so the reach was where I wanted it If I had to do it over I'd get the MGW
Old 07-18-2009, 07:38 PM   #12
slostang's Avatar
Re: Short Throws
Mgw is def the way to go, I'm running a triax with the mgw handle and it works really well. If i ever replace it, it will be with the MGW for sure!
Hi Rob
slostang is offline   Reply With Quote
Old 07-19-2009, 10:30 AM   #13
Re: Short Throws
^^ keep in mind the normal shifter handles that come with the mgw wont work on any other shifter, they used to or perhaps still do make a shifter handle for stock style shifters.
Old 07-20-2009, 06:00 PM   #14
at7311's Avatar
Send a message via AIM to at7311
Re: Short Throws
I got a MGW for Christmas and love it!
at7311 is offline   Reply With Quote
Old 07-21-2009, 05:15 PM   #15
upton7's Avatar
Re: Short Throws
just make sure it has the adjustable shift stops on it. Thats what will protect your transmission. After that just get one thats the right price for you.
Marine Throws Puppy Off Cliff Brent Pictures and Videos 13 03-04-2008 09:41 PM
Guy Throws Two Eggs and Is Arrested for Terrorism, Burglary and Expelled From School Brent The Bar 12 05-11-2007 05:11 PM
Short Vid blownsix Pictures and Videos 2 07-04-2005 04:03 PM
Short shifter cms09071987 Pre-2005 V6 Mustang 14 06-29-2005 09:53 PM
Sorry about the short downtime Brent ME Site Help & Announcements 3 05-10-2005 12:11 PM
08:21 PM
