Throttlebody & Plen. Qest. - Mustang Evolution
Old 04-17-2005, 05:01 PM   #1
douGT's Avatar
IM about to buy the Accufab 75mm TB & P, is there any other things that is necessary to get with it when i get it.
douGT is offline   Reply With Quote
Old 04-17-2005, 05:29 PM   #2
dont think you need anything else. ive heard of some pretty good gains out of this.
Old 04-17-2005, 05:31 PM   #3
douGT's Avatar
thanks, ya im hoping theres a nice gain and its completely polished, so it will match me intake
Old 04-28-2005, 12:19 PM   #4
Rick0636's Avatar
The accufab intake is made for a 70mm tbody, not a 75mm, also the Mac Polished intake is a lot less expensive and made to accomodate the 75mm tbody, with a much better design for performance. The accufab intake looks like a stock intake plenum which has been ported and polished on the outside. I have one of those, and it works quite well with a 70mm Mac tbody.
Old 05-04-2005, 01:50 PM   #5
douGT's Avatar
comes assemblied already and looks better than the "rounded" look i think.
*Large openings that accept 70 or 75mm TB without modification
*Dyno-tuned plenum which elimates the need for an intake spacer
*Direct-Replacement needing no modifications
*Raised and Recontoured Runner for better airflow and consistent volume throughout plenum
Old 05-05-2005, 09:07 AM   #6
even though they say ya dont need a spacer getting one will boost your tq a bit.
AlmostN8 is offline   Reply With Quote
Old 05-05-2005, 01:06 PM   #7
douGT's Avatar
ya i figured a spacer would, i was thinkin about getting one of them also.
Old 05-13-2005, 07:08 PM   #8
douGT's Avatar
i just ordered it, so i got another question. my friend is tellin me i have to take it to a dyno shop or something like that and get it tuned, is this true?
Old 06-01-2005, 09:57 PM   #9
Rick0636's Avatar
The throttle position sensor should regulate your idle, with no adjustment, dont' think you can adjust it, if it isn't working properly the sensor could be bad. Personally I think the accufab stuff is way over priced, but it does look good if that is what you want. I look for performance, low price and if it looks good, that is good too. Last priority though.
Old 06-02-2005, 07:29 AM   #10
douGT's Avatar
im satisfied with it
Old 06-02-2005, 11:42 AM   #11
Rick0636's Avatar
Good, I am glad you are!
Old 06-02-2005, 12:43 PM   #12
That would be a no. Just bolt it on and go. Dont be alarmed they whistle at ya when ya put gass to them.
96 GT 4.6 L
Ported 2004 Upper Plenum
B&M Shifter
Bassini O/R X Pipe
FRPP Adjustable Clutch Cable
UPR Extreme Triple Hook Quadrant
UPR Extreme Firewall Adjuster
Ford 11"Clutch Conversion
C&L MAF
WMS CAI
Aluminum Drive Shaft
95 V6 Vert: 4.2L swap, Trac Lock, Light Cam, Mac Shrorty Headers, More to come.
Gauging Interest P&P Upper & Lower Split Port Herbstang Mustang Parts for Sale and Wanted 0 09-22-2005 08:45 AM
fs: 2 jl 10" subs, 500w mono amp, custom box & wall tedness Mustang Parts for Sale and Wanted 3 05-12-2005 10:42 PM
60mm throttlebody on 98GreenStallion Pre-2005 V6 Mustang 23 01-13-2005 05:57 PM
04:29 PM
