Changing Oil Ques. - Mustang Evolution
Old 04-20-2005, 03:03 PM   #1
douGT's Avatar
Changing Oil Ques.
How much oil does a 2003 GT hold, and how can i idenifty the oil filter in a book or what, the numbers, etc.. First time changing it on this car.
douGT is offline   Reply With Quote
Old 04-20-2005, 03:04 PM   #2
01mineralgrey6's Avatar
owners manual says 6qts with filter- it will sit about half way down the dipstick
motorcraft filter is a 820
fram is a PH2
-Tony
'99 cobra 'vert
Old 04-20-2005, 03:04 PM   #3
djlarryp's Avatar
Region: Arkansas
mine is 6 and i would recomend the motorcraft filter.
djlarryp is offline   Reply With Quote
Old 04-20-2005, 03:05 PM   #4
*edit* I'm too slow...forgive me
Old 04-20-2005, 04:44 PM   #5
6 + filter, I recommend mobile 1 oil and ford oem filter
Old 04-20-2005, 04:53 PM   #6
http://www.greghome.com/images/Maxim...l%20Filter.jpg
thats what the oil filter will look like.
Old 04-20-2005, 05:55 PM   #7
douGT's Avatar
thanks, i know what a oil filter looks like I just didn't really know what the filter numbers were and the quart amount, thanks guys.
Old 04-20-2005, 08:46 PM   #8
No problem
-Tony
'99 cobra 'vert
Old 04-20-2005, 09:11 PM   #9
MonteCitan's Avatar
mid 2002+ calls for 6 quarts with oil filter change (shouldn't change the oil without changing the filter)..
I usually have to put almost 6.5 quarts in to get it midway up the dipstick after starting, filling the oil filter, and letting it drain back.... ....
though I also let my oil drain for about an hour or so..
out with the old, in with the new :yup:
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-28-2005, 12:03 PM   #10
Rick0636's Avatar
Lightbulb
Don't know where you guys are getting this 6, 6.5 quarts of oil in a GT??? I use 5 quarts of synthetic Havoline, and a K&N filter. Dont' know the numbers, just look it up in the book where you buy the filter, or sometimes they will look it up for you. After you put in the 4th quart start the engine long enough for the oil pressure to go as high as it will go, then shut it down, add the last quart, and check the oil level on the stick, never heard of trying to get the oil level half way up the stick either, there is a mark on that stick for full, use it. It is very bad on an engine to run it with overfilled oil, this causes leaking gaskets, and oil burning.
Old 04-28-2005, 06:36 PM   #11
Fishers Stang's Avatar
On my 2002 P71 Vic (shh) 4.6L V8 It reads to use 6 quarts Motorcraft SAE 5w-20 , Filter I use is a Ford Motorcraft FL-820S
Charles
Old 04-28-2005, 08:29 PM   #12
MonteCitan's Avatar
6 quarts w/filter for a mid-late 2002+
Why would you only put 4 in to start then add the rest? that makes no sense to me aside from maybe saving 2-3 seconds rather than waiting for drainback?
Midway to full.. basically anywhere's near the high end of the crosshatch area on the dipstick = GOOD Another thing Ford changed, I believe it was 2001?
- the way the dipsticks are to be read.. the TSB is still floating around somewhere's.
Believe me man.. I work for ford, on fords.. and have for the past 3 years, plus at least another 2 years in my driveway.. 2001 and below are def. 5 quarts however.. Just because yours is, doesn't mean everyone elses' is..
PS no need to use the face... I meant to say the 'marked' area on the dipstick .. between max and min.. Sorry it was misread, I figured it was common sense
Old 05-01-2005, 12:16 PM   #13
Rick0636's Avatar
I take it the newer 4.6, 02 up or whatever has a deeper oil pan on it or something. I think I remember something about the 99-00 engine being a Romeo plant engine, the others may be Windsor. What I said about overfilling engines is still true. Not insulting anyone, sorry, my mistake. I have never worked for Ford, but have worked on my own since about 67, and got an AAS in Automotive Systems in 99.
Old 05-01-2005, 01:49 PM   #14
:d
Charles
Old 05-01-2005, 07:55 PM   #15
MonteCitan's Avatar
Still a Romeo engine afaik.. I believe it was a running change.. I think a month after mine was built they started calling for 5w20 in the 4.6s, too..
who knows with ford
haha sorry if I came across as an ***..
overheating after changing the oil filter adapter 2003stangmachI 1996-2004 Mustang GT 8 10-29-2009 08:26 AM
Changing my blower oil, any tips SpectorV 1996-2004 Mustang GT 5 04-07-2006 12:22 PM
About changing oil... Ibanezplayer272 Pre-2005 V6 Mustang 21 02-23-2006 09:33 PM
changing oil pickup, how to prime it? fast64 1979-1995 Mustang GT 4 04-21-2005 05:51 PM
Think changing your oil every 3k miles is good? Think again Monkey Pre-2005 V6 Mustang 14 02-24-2004 05:39 PM
12:15 AM
