how much can my car take? - Mustang Evolution
Old 07-21-2009, 05:10 PM   #1
upton7's Avatar
I bought a 99 4.6. I'm buying forged probe pistons h beam rods, and a forged crankshaft. I might bore it over .20 or .020 whichever it is. Then have the heads gasket matched ported and polished and a triple angle valve job. I'm gonna get a cam with more lift then get a 90 mm maf. maybe 42 lb injectors headers cai and about all of the bolt ons. I'll get an aluminum flywheel and a heavy duty clutch. Right there i'm pretty sure i'm lookin at around 350 hp will my t3650 tranny yokes rear and and everything hold up to this power or will i need to beef up some more ****.
Old 07-21-2009, 06:33 PM   #2
hottcobra's Avatar
Re: how much can my car take?
you drivetrain will be fine at that hp.
Old 07-21-2009, 06:35 PM   #3
upton7's Avatar
it is a stroker kit btw it'll be around 300 cubic inches. Would it be ok at maybe 400? (just in case)
Old 07-21-2009, 06:38 PM   #4
hottcobra's Avatar
you still be fine. the trans. would be the first to go, well after the clutch.
Old 07-21-2009, 06:40 PM   #5
upton7's Avatar
tranny and rear end are my main concerns they are the most expensive besides the motor
Old 07-21-2009, 06:41 PM   #6
upton7's Avatar
you know what else i can do to gain hp?
Old 07-21-2009, 06:51 PM   #7
this man is always sayin hes gunna doo thiss n dooo that jw do u do any of the things you post about? jw?
saleenman is offline   Reply With Quote
Old 07-21-2009, 07:14 PM   #8
I'm pretty sure he is "gunna"...not sure if you know anything about building engines, but they take time, and are expensive to build, especially the route he is taking. I'm pretty sure money is an object to him as it is to most of us on the site...it can take guys years to build an engine the way they want it, not mention the drivetrain and tranny to match. Doing something this sophisticated requires serious planning and includes several variables to take into consideration. It is important to have everything planned out beforehand so it is done right the first time and causes as little headache to him and his wallet as possible.
He obviously likes to put his plans and ideas on the forum for some positive criticism and advice as you may have seen in other posts of his...I would do the same before tackling a project on that scale, it just makes sense...so chill out son!
Old 07-21-2009, 07:15 PM   #9
Upton, where'd you get the 4.6 from?
Old 07-21-2009, 07:37 PM   #10
:Actually i know ALMOST everything there is to know about building engins ive ben doing it for years there is NO critisizm in what i seaid at all so u can chill son. i was just curious on weather or not he DID any of theses so called projects that he has ben asking about reason being is so i can find out how his results are. and if he was doing all of these builds such as the spray and the building of the block boring ect....which one one he had the most success with damn for all i know the dudes a millionare just goin around building blocks and blowin them up soooo who knows SON!
Old 07-21-2009, 07:41 PM   #11
upton7's Avatar
I'm serious about this i have the engine almost all the way torn down. My buddy who is a mustang fan is putting an ls1 in his 93 notchback hooked me up with his uncles motor that has a problem i haven't found out what is wrong yet i was told maybe a lifter. All the other things i talked about were not done because of money time or the lack of gain from what i was doing. I have to post on here first to find out how much something will cost because i'm paying for it I don't have rich parents like some.
Old 07-21-2009, 07:42 PM   #12
upton7's Avatar
Oh that post yes i'm still doing the same crap to the engine but i'm not gonna spray it now thats the only change with this project.
Old 07-21-2009, 07:50 PM   #13
Wow, I should be impressed, you know ALMOST everything there is to know about building engines...if you were serious in your initial post and that was your intent I apologize, but when you say "this man is always sayin hes gunna doo thiss n dooo that" to me it sounds like someone who hasn't spent a lot of time on here making unnecessary smartass comments.
Old 07-21-2009, 07:56 PM   #14
hottcobra's Avatar
ok now ladies. try to keep it on topic.
Old 07-21-2009, 08:02 PM   #15
sorry boss
Upton, you'll have to let me know when you get done with the build, I'll have to come down and see it or something, sounds like a badass setup.
Old 07-21-2009, 08:05 PM   #16
upton7's Avatar
i'm hopin so and ya we'll have 2 do that. I just want to do everything i can while i got the engine on the stand and torn apart. If anyone knows somethin i may be forgeting or has a suggestion i'm open to it.
Old 07-21-2009, 08:06 PM   #17
thanks for the appoligy not a prob just her tryin to c what ppl r up 2 and c what other ppl are trying to do and how there outcome is.....any way the setup sounds like a nice work in progress and would like to follow up and see how the dude makes out.
Old 07-21-2009, 08:12 PM   #18
spray is always fun tho man good bang for the buck thats for sure iv seen low 12 sec passes out of a stk 4.6 with 150 shot with correct gearing.
Old 07-21-2009, 08:13 PM   #19
upton7's Avatar
Its kool no one on here will hold a grudge.
Old 07-21-2009, 08:15 PM   #20
always good
Old 07-21-2009, 08:19 PM   #21
upton7's Avatar
Well my mechanic said it can mess alot of stuff up which is true and it sometimes its fine but i don't think i'll take the risk. But who knows i may do it down the road. Thats something that can be done at anytime thankfully.
Old 07-21-2009, 08:37 PM   #22
Hey good to hear man, just trying to help out a friend, I'm sure you know where I'm coming from...as upton7 said, no one here holds a grudge, hope to see you around more
Old 07-22-2009, 12:55 PM   #23
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
i on the other hand don't know a crap load about engines, just why they work. i was thinking though, you could do like 50-75 with a wot switch... being that low with your basically bullet proof engine shouldn't hurt anything from what i've heard and you'll have a little bit extra when you need it :dunno:
sounds like a good build up though, can't wait to start mine
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-22-2009, 03:32 PM   #24
Ninethourpm's Avatar
YES THEY DO
2000 silver 3.8 5 speed,smoke tint,cold air intake,MAC Long tubes, MAC Catted H,MAC GT catback, SCT Livewire w/ Bamachips tune,
17x8Fr 17x9Rr Bullit Wheels More to come......
96 honda magna vf750, K&N, Vance and Hines pipes Rejetted carbs
Ninethourpm is offline   Reply With Quote
Old 07-22-2009, 05:42 PM   #25
upton7's Avatar
Originally Posted by Ninethourpm View Post
YES THEY DO
Really? Who?
Old 07-22-2009, 06:13 PM   #26
against imports and camaros
Old 07-22-2009, 10:10 PM   #27
upton7's Avatar
i got no problems with camaros or any american vehicles
Old 07-22-2009, 10:50 PM   #28
^^^much agreed...if for some strange reason I lost my current stang and couldn't get another mustang, I'd have no problem owning a camaro, challenger, or any other American car. You couldn't pay me to own an import, especially right now.
Old 07-23-2009, 06:32 AM   #29
All my cars and trucks where fords. only imports are my current bike and my last bike. I might get a V rod next but the rest of harley i dont care for.
Old 07-23-2009, 11:10 AM   #30
Yah, only import around my house is the 83 Honda Shadow.
The v rod series night rod is *****in...
Old 07-23-2009, 04:50 PM   #31
upton7's Avatar
I like harleys as far as bikes go but i understand someone buying imported motorcycles since harleys are so expensive. but as far as cars and trucks go no way
Old 07-23-2009, 05:31 PM   #32
I dont like them because there way overpriced and way too slow My 750 (45in) is makeing the same power as a 96in Harley.
Old 07-23-2009, 10:58 PM   #33
I don't mind some of the harleys, like the 883 low's and the v-rods. They are nice bikes, but the price tag on the v-rods hurts.
The only thing your gonna miss with an import bike is the harley sound.
It's sort of like buying a v6 mustang, you can work on it and make it faster than the v8 mustang, but it's still going to sound like a sixer at the end of the day, no v8 rumble.
That's how my honda is, it's real nice at idle and in the lower rpms, but higher up Japan's colors show through.
Old 07-24-2009, 01:30 AM   #34
Region: Oregon
my import has about 77 fwhp... (some guy dyno'd one on a site a while back) so its lacking in all areas... luckly i have a mustang to make up for it.
Old 07-24-2009, 03:39 AM   #35
Mine sounds like a V-Twinky at low rpms (up to 4K) but beoyond that it sounds like a race car. Of course if you reved a HD that high youd be cleaning its internals off the street. V4s are fast Vtwins are half assed.
1990 LX show car being auctioned off on ebay CHECK THIS CAR OUT! fordguy23 Mustangs for Sale and Wanted 0 10-11-2006 10:03 AM
Pics of the car with fresh coat of water less car wash SpectorV Mustang Audio & Video 22 02-23-2004 08:12 PM
02:26 AM
