steeda clutch cable - Mustang Evolution
Old 04-23-2005, 07:56 PM   #1
chipshot101's Avatar
steeda clutch cable
has anyone put that steeda clutch cable set up in there car?? is it very hard? do you have to drop the tranny or anything??
I have the need for speed! :burnout: 2000 Black GT. Steeda tri ax, Mac cat back, K & N CAI. Diablosport chip, shift light,U/L rear control arms, steeda wing, 3:73 in da rear, no money I have a baby!
chipshot101 is offline   Reply With Quote
Old 04-23-2005, 08:28 PM   #2
you dont have to drop the tranny. maybe spector v will chime in he has done this before.
Old 04-24-2005, 10:16 AM   #3
i wouldnt put a steeda cable, what are are you trying to do exactly? If you want to adjust your clutch petal height (all you can do with a cable) then you need to go to upr and get there clutch quadrent and firewall adjuster (get the quadrent with like 3 hooks or something)
but be warned!!!! just cuz you can lower the petal's ENGAGMENT point the petal WILL STILL floop due to the slack by lowering it and raise its wonderful little self all the way back up to the top so you still have to raise your foot up just as high... it just dont start grabing till you are alot farther down...
www.maximummotorsports.com has a kit that moves the clutch stop down lower so... the petal cant raise up as high... this is what you will need, The best adjustment is taking all the slack out of the petal so its firm at the top and you have a half inch of petal when you start to push it in before the clutch starts to slip (go down the road at 55mph hold the gas constant with your right foot and push the clutch in slowly if you get half an inch before the rpms jump up your good.
If i let slack get in my petal my throw out bearing will tick ASAP its horrid... If i keep the slack out of it its fine... just keep a half inch in it before it starts to slip.
Old 04-24-2005, 11:37 AM   #4
I plan on buying the steeda package with the quadrant and firewall adjuster. is it worth swaping out? I'm a tall dude,is it hard to install?
New clutch installed.. need new cable now Rascal Pre-2005 V6 Mustang 5 06-03-2010 07:55 PM
Clutch cable advice......... outlawfrog 1996-2004 Mustang GT 12 12-07-2009 04:57 PM
Steeda Cable Jeff2000GT 1996-2004 Mustang GT 5 02-17-2009 10:21 PM
adjustable clutch cable jt2000gt 1996-2004 Mustang GT 5 12-28-2007 07:43 PM
Steeda Clutch Cable Kit In2dreamingbig 1996-2004 Mustang GT 5 09-01-2006 06:05 PM
08:27 AM
