96 gt getting 03gt motor. any advice?? - Mustang Evolution
Old 07-27-2009, 03:43 PM   #1
Exclamation 96 gt getting 03gt motor. any advice??
Hey I have a 96 gt with a ton of miles and I was able to get a 03 gt motor out of a rolled car with only 50k on it. I was told that it will drop right in with only minor differences. I know there is a sensor on my manifold now that I need to tap and install into the new intake but besides that I think it will go right in. Is there anything else that I will need to change or will it bolt right up. Also will my computer and harness work with the new motor if I dont use the COP. Any help would be GREAT!!
kOakley1 is offline   Reply With Quote
Old 07-27-2009, 06:16 PM   #2
Re: 96 gt getting 03gt motor. any advice??
everything works without a hitch, you can retain the coil packs so you wont have to modify the wiring harness. if u have an aliminum crossover on your old intake u can swap it over to the pi inatke. it is only 4 bolts and a little of silicone required. other than that, it is basically straight forward.
96 GT- Who knows what's in it.
Old 07-27-2009, 08:00 PM   #3
ok thanks I did not know that I could switch the crossovers. What about the ECU? Will I need a custom tune? Mine was programmed with a hypertech programmer but I no longer have the programmer. Will my ECU figure itself out or no?
Old 07-27-2009, 10:12 PM   #4
u will benifit more with a tune, u will run a little rich until then. the gains from the pi motor alone will make your car feel like another car.
Old 07-28-2009, 09:44 AM   #5
Hell ya I am looking forward to it. I will let you know how it goes and post pics. I ended up getting a whole new interior also so it really will be like a new car. I have an extra set of PI heads now to if anyone needs them I will get rid of them cheap. I can also ship them dirt cheap since I work at Fedex.
Thanks for the input!
Old 07-28-2009, 04:06 PM   #6
no problem dude, good luck with the swap
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
advice roach 1996-2004 Mustang GT 4 05-16-2007 12:47 AM
03GT upgrades o3mustangGTafs 1996-2004 Mustang GT 1 07-21-2006 01:02 AM
desire advice... stock investment type advice... dark The Bar 4 04-23-2006 06:07 PM
Need Some Advice Herbstang Pre-2005 V6 Mustang 9 01-24-2005 03:09 PM
07:45 PM
