Is this a pretty good oil change? - Mustang Evolution
Old 07-27-2009, 08:57 PM   #1
upton7's Avatar
6 quarts royal purple 5w-20, lucas oil treatment, and a wix filter?
Old 07-28-2009, 06:46 AM   #2
bbunt302's Avatar
Re: Is this a pretty good oil change?
Sure.
Scary stuff.
Old 07-28-2009, 07:36 AM   #3
wix or ford for oil filter so sounds good
Old 07-28-2009, 08:20 AM   #4
DarkShadows's Avatar
sure
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 07-28-2009, 10:52 AM   #5
I don't think you would need the oil treatment though unless your car is burning oil or you're having engine problems.
http://i5.photobucket.com/albums/y200/mustangfan2003/MC.jpg?t=1196874772
Mustangfan2003 is offline   Reply With Quote
Old 07-28-2009, 01:46 PM   #6
make sure you drain out the old oil first
make sure you put the drain plug back in before you put the new oil in
make sure you pour the oil into the hole that says "OIL" on it, or if it is upside down, it might say "710"
also old motor oil is carcinogenic so wash your hands thoroughly for at least 20 seconds when the transaction is complete.
good luck and may god have mercy on your soul
ThaWill is offline   Reply With Quote
Old 07-28-2009, 06:47 PM   #7
Keto77's Avatar
lmao
1998 GT, 5 speed, Built by Anderson Ford, PI Heads , Intake , lowered 2 In , 3.73 Gears , BBK under drive pulleys, air sensor, k&n cold air, 75mm trick flow throttle body, Bassani exhaust, Hurst short throw shifter, Steeda high flow fuel pump , 24 lb injectors, Comp Cam slotted rotors, Mach 1 chin spolier
Keto77 is offline   Reply With Quote
Old 07-28-2009, 07:07 PM   #8
also no matter what they tell you do not wash the old oil out of the car.
Old 07-28-2009, 08:58 PM   #9
bbunt302's Avatar
Make sure you the gasket comes off with the old oil filter. That's the key to a "pretty good oil change".
Scary stuff.
Old 07-29-2009, 09:37 PM   #10
upton7's Avatar
i've changed oil about 300 times i'm just wondering if the products i'm using are a pretty good mix
Old 07-30-2009, 12:02 PM   #11
How many cars do you have!? 300 oil changes is like 900,000miles/75years worth of oil!
Old 07-30-2009, 12:07 PM   #12
The products are fine
Old 07-30-2009, 12:08 PM   #13
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
my dad told me that like 10000+ times, and i was helping my neighbor do an oil change on his civic and we couldn't figure out why oil was pouring out of the car... LOL
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-30-2009, 05:12 PM   #14
upton7's Avatar
exageration i used to work at a shop probably did around 50-75
Old 08-06-2009, 01:30 AM   #15
JoeyR's Avatar
Region: Oregon
Send a message via MSN to JoeyR
Lmao that poor neighbor, he must have think u broke his civic. lol i can just picture the oil pooring out all over the ground , wtf did you do to my car.
2000 Mustang GT, SCT Tuner, K&N Cold-Air-Intake, BBK Short Throw, FR 3.73's, PaceSetter Longtubes w/3" streight pipe w/ resonators
JoeyR is offline   Reply With Quote
Old 08-06-2009, 01:57 AM   #16
Tape's Avatar
personally I think using the high priced oil on a street car is a waste of money, I have used the cheapest oil for years which in my case is walmarts super tech every 4000 or when the color of the oil turns to a darker bronze color. I have 130k miles and still run 12's and 8.20's in the 1/8.
Tape is offline   Reply With Quote
Old 08-06-2009, 10:21 AM   #17
Herbstang's Avatar
Personally I'd rather spend the money to be on the safe side
Old 08-08-2009, 12:23 PM   #18
ive actually done some calculations and when i was younger and worked as an oil change ***** at the dealer, ive done over 3800
iamdat is offline   Reply With Quote
Old 08-10-2009, 07:15 PM   #19
occhopperman27's Avatar
Mobile 1 full synthetic, wix filter
occhopperman27 is offline   Reply With Quote
Old 08-11-2009, 04:33 PM   #20
You should not need the oil treatment with Royal Purple oil.
kercolla is offline   Reply With Quote
Old 08-13-2009, 10:14 PM   #21
redcobravert's Avatar
any synthetic will be good its not gonna give u more power with the spendy stuff
redcobravert is offline   Reply With Quote
Why Change your Oil???? Cajun JungleBoy The Bar 13 04-17-2007 01:59 PM
Oil Change F*ck Up Herbstang The Bar 14 11-11-2006 11:55 AM
Oil Change 00StangV6 Pre-2005 V6 Mustang 15 06-09-2006 11:22 PM
Oil Change megax29 Pre-2005 V6 Mustang 31 09-03-2004 07:13 PM
Oil change....... cagedthought Pre-2005 V6 Mustang 24 10-04-2003 12:35 PM
09:02 PM
