Motive Gears - Mustang Evolution
Old 04-26-2005, 11:43 AM   #1
Motive Gears
I'm going to swap out my gears soon.I've spoken with an installer and he recommends Motive gears.I know Ford gears are the popular choice here,but just curious if anyone has tried the Motives,or heard of any pros and cons.
2001 Cobra Mineral Grey
Manual trans
Ghostbuster is offline   Reply With Quote
Old 04-26-2005, 12:45 PM   #2
oem ford gears... dont get any others... you will break the tlok before you break the gears. Some brands can whine due to their design/makeup get ford and get em professionally installed by someone who also puts a warranty for gear whine and XXX mile warranty for install screw ups... if they whine when they put em in.. they didnt do em right.
Old 04-26-2005, 03:16 PM   #3
get ford gears youll be fine with them. or get richmond gears which are stronger but they tend to whine even when installed correctly.
Old 04-27-2005, 07:57 AM   #4
Guys,I agree with you,it would be hard to do better than OEM Ford.Intersesting thing is...two professional installers I've talked to both prefer to use the Motives,and will back up the work with a warranty.I just want this done right the first time.I may ask if he'll consider using the Ford gears.
Manual trans
Old 04-27-2005, 11:08 PM   #5
yor call, i would prefer ford or richmond though.
Old 04-28-2005, 07:37 AM   #6
douGT's Avatar
did they tell you how much it would cost for them to put them in, i plan on getting gears soon and im debatin at taking it in or tryin it myself.
douGT is offline   Reply With Quote
Old 04-28-2005, 08:08 AM   #7
If you want it done RIGHT the first time then get an 8.8 rear end... if this is for the 96 then you will probably save a few bucks if not break even.. complete rear ends with out axles (reuse your stock ones) for 725 cant beat that... with 3.73s already installed and a tlok unit... i wish i had done that, but for 99 ups the axles are not long enough....
Old 04-28-2005, 08:41 AM   #8
Both quotes were very high...500-600.These were from pro installers with warranty.
SpectorV,its for my 03,it has traction control wich I guess makes the install a little harder...?
Manual trans
Old 04-28-2005, 06:07 PM   #9
douGT's Avatar
500-600, wow, didn't think that high. well i guess its worth it with a professional and with a warranty. are these that hard to install or what?
Old 04-28-2005, 06:08 PM   #10
its not too hard http://www.angelfire.com/theforce/5o...5ohtech001.htm
Old 04-29-2005, 05:43 AM   #11
232Stang,thats a good link.Thanks.
Manual trans
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Replacing stock motive gears to new? NavyGT99 General Mustang Discussion 7 08-12-2008 07:16 AM
4.10 gears powerhungry966 Pre-2005 V6 Mustang 7 10-23-2005 06:53 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
01:07 PM
