hot to tell the dif between PI motor and reg motor - Mustang Evolution
Old 07-28-2009, 05:05 PM   #1
Keto77's Avatar
the reason I ask this , (new to ford) my buddy across the street has a 4.6 also and our motors dont look alike mine has 2 coil packs in the front of the motor and his does not.
1998 GT, 5 speed, Built by Anderson Ford, PI Heads , Intake , lowered 2 In , 3.73 Gears , BBK under drive pulleys, air sensor, k&n cold air, 75mm trick flow throttle body, Bassani exhaust, Hurst short throw shifter, Steeda high flow fuel pump , 24 lb injectors, Comp Cam slotted rotors, Mach 1 chin spolier
Keto77 is offline   Reply With Quote
Old 07-28-2009, 05:55 PM   #2
Re: hot to tell the dif between PI motor and reg motor
That picture is a non-PI IIRC
Old 07-28-2009, 06:07 PM   #3
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
96-98 are non pi aren't they?
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 07-28-2009, 06:11 PM   #4
That would be correct. I believe all PI are COP...might be wrong. Gonna research to find out real quick....
Old 07-28-2009, 06:15 PM   #5
Keto77's Avatar
what IIRC
Old 07-28-2009, 06:17 PM   #6
1996-1998 are non PI
1999-2004 are PI
Old 07-28-2009, 06:20 PM   #7
Originally Posted by Keto77 View Post
what IIRC
If I Recall Correctly
Old 07-28-2009, 06:23 PM   #8
Keto77's Avatar
opps typo I guess i should have said whats IIRC stand for
Old 07-28-2009, 06:28 PM   #9
yea plug wires - 96-98 gt 99-00 dont have them and the oil filler is on the pass side, 01-04 have oil filler on drivers side, they say 99-00 are stronger, they were built at the romeo plant.
Old 07-28-2009, 09:47 PM   #10
Originally Posted by keto77 View Post
opps typo i guess i should have said whats iirc stand for
............................................________
..............?.....__.........................................:`.........../
............./__.(.....“~-,_..............................,:`........../
.........../(_....”~,_........“~,_....................,:`........_/
..........{.._$;_......”=,_.......“-,_.......,.-~-,},.~”;/....}
...........((.....*~_.......”=-._......“;,,./`..../”............../
...,,,___.`~,......“~.,....................`.....}............../
............(....`=-,,.......`........................(......;_,,-”
.............`~.*-,.....................................|,./.....,__
,,_..........}.>-._...................................|..............`=~-,
.....`=~-,__......`,.................................
................................`:,,...........................`..............__
........................................_..........._,-%.......`
ThaWill is offline   Reply With Quote
Old 07-28-2009, 09:48 PM   #11
Old 07-28-2009, 10:15 PM   #12
Keto77's Avatar
ah I see .... I think after alot of reading tonight i have it figured out . Ford newbie here, feel like a dumb kid again lol
Old 07-28-2009, 11:07 PM   #13
We all start somewhere...you should see what I used to post a few years back when I got into the car thing lol.
Old 07-29-2009, 12:03 AM   #14
It's all good man. We have all done that at one time or another. We are just messing around. Just try not to take things too seriously around here and you will fit in fine.
new motor rswan112 Pre-2005 V6 Mustang 3 03-06-2007 09:50 AM
What motor.. bullitt482 General Car Discussion 55 02-23-2007 03:51 AM
What motor..... bullitt482 General Car Discussion 9 02-16-2007 04:44 PM
New Motor GT-Eater Pre-2005 V6 Mustang 30 07-18-2005 12:01 AM
Motor coolstang Pre-2005 V6 Mustang 5 01-21-2005 09:19 AM
» Members Mustangs
Mustang GT
Kev09GT
Rex
Tippy
Add your Mustang
10:06 PM
