This Just Happened HELP - Mustang Evolution
Old 07-30-2009, 09:02 PM   #1
Ok so i was driving my car and i came to a stop and put it in park then it turned of,
the clutch rattled,
The battery light came on and the radio stayed on
What could cause this to happen?
LuisFlores99GT is offline   Reply With Quote
Old 07-30-2009, 11:15 PM   #2
upton7's Avatar
Re: This Just Happened HELP
maybe you let out on the clutch pedal b4 you turned the car off?
Old 07-30-2009, 11:38 PM   #3
Pulling a rookie is always embarassing. I remember I had my car for about 3 days and I did it in Taco Bell drive-thru.
19Delta is offline   Reply With Quote
Old 07-31-2009, 12:29 AM   #4
Ha,
No thats not what happend,
Maybe this will be better,
One day as i was driving i was making a right turn the car just died on me, the steering wheel locked and so did the breaks i then turned it on and it was just fine
Old 07-31-2009, 12:36 AM   #5
Does it have trouble starting at all?
Old 07-31-2009, 12:47 AM   #6
Not at all,
This happens every once in a while the idle is horrible when im in neutral or in park the rpms will drop very low and the car will sound like its about to die but it will kick back in
Old 07-31-2009, 12:50 AM   #7
hrmmm...02 sensor maybe? I have no idea other than that.
Old 07-31-2009, 03:19 AM   #8
OsirisGuy's Avatar
Any codes popping up, even for a second?
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 07-31-2009, 08:01 AM   #9
"Ok so i was driving my car and i came to a stop and put it in park then it turned of,
the clutch rattled"
um there is your issue you have an automatic (aka you put it in park, which is impossible with a manual) then your clutch rattled, your car has both auto and manual transmission parts. I would start there
lol did you let out of the clutch in gear, if so there is your problem
Old 08-01-2009, 01:52 AM   #10
Racin02GT's Avatar
Send a message via AIM to Racin02GT
the clutch rattled"
And it took 8 posts for someone to catch that
Racin02GT is offline   Reply With Quote
Old 08-01-2009, 03:32 PM   #11
I was about to say the same thing Brandon...
What happened to... Stumpy ME Site Help & Announcements 8 05-03-2007 01:00 PM
Whatever happened to 69boss429 The Bar 12 02-23-2007 04:58 PM
It happened... Zim The Bar 34 02-12-2007 04:30 PM
Whatever happened too..... Brent The Bar 16 12-12-2005 09:13 PM
What happened elijah The Bar 23 10-07-2004 01:52 PM
11:16 AM
