Temp Gauge not working? - Mustang Evolution
Old 08-03-2009, 08:57 AM   #1
Hi all!!,
New to this website it looks great!! I recently baught a 1996 GT Convertable. 4.6l and the temp gauge isnt working. I replaced the sending unit on the top of the motor but it still isnt working. I was told there might be two sending units. Is this true? and if so ware is the second and what is the part # if you know? Thanks for your help in advance.
BILLFORD01 is offline   Reply With Quote
Old 08-03-2009, 09:24 AM   #2
Re: Temp Gauge not working?
you can check the cluster as its pretty easy to get out, just two screws facing upwards above the gauges and they pop out. Then the bolts holding the cluster in (4 of them).
The headlight knob is the only gotcha to the removal..... its a nightmare lol you need a bent nail and you have to pull the metal slit you can see in the slot toward you and then pull the knob to slide it off.
Old 08-03-2009, 09:53 PM   #3
it may be a cluster issue but sensors are quite common on these cars. there are indeed to coolant temp sensors. 1 for the computer and 1 for the cluster. the one right next to the thermostat housing is for the computer. the other is toward the back of the intake, just look for it, you cant miss it. the sensor is 20$ from the dealer. i dont recommend using any other sensor but the dealer one. part number for that is F68Z-10884-AA
to test, theres a resistance value that should vary with engine temperature. im not sure of exact figures but at 20$, its worth a shot.
iamdat is offline   Reply With Quote
Old 08-06-2009, 10:01 AM   #4
Looks like it could be the gauge it self on the dash. I replaced the correct sensor for the gauge and it still dosent work. I also grounded out the gauge to see if the gauge would jump or move and it still didnt work or move. any other suggestions? any one know ware I can get a factory gauge from? Ebay dosent have any.
Old 08-06-2009, 11:02 AM   #5
you can check the needle, if it has aftermarket gauge covers it may be that its to tight and it wont move~ ive seen this happen
Old 08-06-2009, 11:04 AM   #6
nope its factory gauge in the dash.
speedometer and gas gauge not working?? rob913 1979-1995 Mustang GT 0 07-03-2010 08:00 AM
1995 convertable 5.0 temp/fuel gauge problem rwb223 1996-2004 Mustang GT 3 03-10-2010 12:55 AM
IEQUUS water temp gauge , glow brand new mac sk Mustang Parts for Sale and Wanted 3 04-26-2007 06:33 AM
Autometer Pro-Comp Ultra Lite Water Temp Gauge Ibanezplayer272 Mustang Parts for Sale and Wanted 0 01-30-2006 02:01 PM
Autometer Lunar Water Temp Gauge FS stangin99 Mustang Parts for Sale and Wanted 0 05-16-2005 04:11 PM
04:27 PM
