CODE PULLED P1443? - Mustang Evolution
Old 08-03-2009, 10:29 AM   #1
CODE PULLED P1443?
Any ideas on what this code means and how to fix it? I did a search and found some answers on the V6 forums but I dont think its the same answer cause mines a v8.
BILLFORD01 is offline   Reply With Quote
Old 08-03-2009, 10:35 AM   #2
Re: CODE PULLED P1443?
That code holds true whether you drive a 4, 6, or 8 cyl. It's your purge flow sensor is going/gone out.
Old 08-03-2009, 10:42 AM   #3
ware is the purge flow sensor located?
Old 08-03-2009, 06:06 PM   #4
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Quick Google pulled this up:
"It is on the passenger side close to the firewall. One hose comes from the vapor canister so that should help you find it or go buy it first so you know what you're looking for."
DarkShadow is offline   Reply With Quote
Old 08-03-2009, 09:39 PM   #5
dont listen to this info. a p1443 is low purge flow Or no purge flow detected
a number of things can cause this to happen such as a canister purge soleniod (common!), canister purge sensor (common!), wiring, pcm, or even a charcoal canister itself. to condemn the sensor without a proper diagnosis is ignorant and a waste of money!
iamdat is offline   Reply With Quote
Old 08-04-2009, 07:29 AM   #6
Ok, so, don't listen to my post yet you go ahead and include what I said as one of the COMMON problems?
Ok, then, I guess he shouldn't listen to your info either.
Old 08-04-2009, 07:33 AM   #7
you saying that is the problem when it might not be is throwing away money. i suppose you also get a code p0401 (egr insufficient flow) and automatically replace the egr valve when infact its the DPFE sensor. replacing the common problem is taking a stab in the dark and throwing money away. do you like pissing money away? especially when these emmisions parts arent exactly cheap.
Old 08-04-2009, 09:31 AM   #8
I never said replace the part dip ****. I said that was his problem and corrected his statement that the info he had already searched for and found did not change for a V8 like he was assuming. If you use some form of reading comprehension and put down the crack pipe, you'd realize it was someone else that flat out stated a google result of ""It is on the passenger side close to the firewall. One hose comes from the vapor canister so that should help you find it or go buy it first so you know what you're looking for.".
No where in my post did I say "Go buy parts and replace them and hope it works".
Old 08-04-2009, 09:41 AM   #9
first of all, you name called. i think that deserves a BAN! ****ing ******. ok now, how else am i supposed to understand this? go pull the tampon out your *******. you play with a cathether or something you overgrown sloth. there, i can play the name calling game too!
Old 08-05-2009, 04:33 AM   #10
Tape's Avatar
*popcorn*
Tape is offline   Reply With Quote
Old 08-05-2009, 08:38 AM   #11
back on topic, any more back and forth action and this thread will become locked.
Old 08-05-2009, 08:46 AM   #12
I took it to PM's yesterday...
Old 08-05-2009, 12:57 PM   #13
Now there's a shame I was jolly well enjoying that to & frow banter, golly I thought we English could get into it, but that was impressive. I learned lots of new words & expressions I wasn't totally familiar with & now I'm looking for an opportunity to use them. I particularly liked the "pulling of a tampon from one's *******" & the reference to playing with a catheter, very imaginative, the "Overgrown Sloth" was also creative. Sorry it all had to end so suddenly.
English Paul is offline   Reply With Quote
Old 08-06-2009, 11:20 AM   #14
well thanks for all your suggestions boys!! sorry it got a little heated!!! The purge sensor was the problem. I replaced it and cleared the codes and so far 3 days later and 100 miles and no "check engine" light!!!
Check engine code- p1443 embecker Pre-2005 V6 Mustang 7 05-12-2014 12:22 AM
1996 Mustang P1443 Evaporative Emissions (EVAP) Canister Purge (CP) Valve Brent Pre-2005 V6 Mustang 33 01-30-2011 08:32 PM
got pulled over..AGAIN meteorachick The Bar 19 08-13-2005 12:21 AM
Code P1443 How to fix it? Neptuno Pre-2005 V6 Mustang 2 09-03-2004 08:28 PM
06:24 AM
