Short throw shifter - Mustang Evolution
Old 08-04-2009, 10:48 PM   #1
upton7's Avatar
Short throw shifter
I just installed my hurst short throw. I have the 3650 tranny that uses that lil plastic piece. It came with it cuz i guess the stock black ones have been wearing out. It didn't look the same and didn't "stick" on. I just put it on and it would stay on a lil bit then i stuck it down in there. I don't know if its supposed to stay on tight to the lil ball at the end or if it just kinda sits in there but it seems like the shifter always wants to go right. Like if im shifting from 1st to second it will want to pull into 4th gear. If i pay attention to what i'm doing ill hit 2nd everytime but not as smooth as stock. Could that lil plastic piece be messing it up?
Old 08-05-2009, 08:41 AM   #2
Re: Short throw shifter
you can reuse the stock part if its not worn I would guess. I dont know how hurst shifters are so I cant tell you if its operating correctly. I dont think that little plastic cup ball is causing any issues with what you are describing. That is related to the spring pressure of the shfter.
Old 08-05-2009, 06:33 PM   #3
Gt.Vert's Avatar
i just installed my mgw shifter this weekend...i know exactly what you are talking abt ...it might be different but heres the thing on the shifter itself there should be two bolts that are on the top and bottom of the whole shifter...you have to goto 3rd gear and push in the bolt till it hits the shifter...than goto 4th and push the bolt same way in and it should hit it all the way in....i had the same problem and when i fixed the bolts all the way in from 3rd and 4th gear they worked fine...try it and tell me whts up
oh and the ittle plastic peice at the bottem just stick on it..i doubt thats the problem
Gt.Vert is offline   Reply With Quote
Old 08-05-2009, 08:11 PM   #4
upton7's Avatar
Well i have the adjustable stops well adjusted. I put on the stock plastic and it seems to be workin a lil better. The instructions said somewhere something about adjusting tension. Is that just meaning the stops or are there some other bolts.
Old 08-05-2009, 08:28 PM   #5
Out of curiousity, what made you decide on Pro-50? ANd the tension is adjusted elsewhere, not by the shift stops.
Old 08-05-2009, 08:40 PM   #6
upton7's Avatar
i don't have the pro 50 i got the hurst
Old 08-05-2009, 08:41 PM   #7
Yeah, it's been a long day...that's what I meant to type. lol
Old 08-05-2009, 10:52 PM   #8
upton7's Avatar
lol i know what you mean. I got it cuz its a good brand i know mgw is better but its still a good shifter without a doubt and its what they put in the badass 60's and 70's muscle cars. So basically for the name lol.
Old 08-06-2009, 11:08 AM   #9
you may have a way to release pressure on the springs making it not as "springy" as you shift through the gears~ not sure on Hurst. The shift stops are pretty much worthless, make SURE they are not close to touching the shift lever.
Old 08-06-2009, 09:57 PM   #10
upton7's Avatar
Yup i read the instructions, and i'm going to do it monday i ordered a hurst shifter stick and white knob i'll do it all at the same time. How do u think it will look with the chrome stick. I"m hoping it will look like the roush shifter kit but with everything hurst
Old 08-07-2009, 01:19 PM   #11
OsirisGuy's Avatar
My Pro5.0 is set to always go into neutral whenever no engaged in gear. I don't know how that compares to stock or the problems you are experiencing. Mostly just a FYI.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 08-07-2009, 05:20 PM   #12
upton7's Avatar
It's fine i think now i think i just needed to get use to it. And i'm starting to.
Short Throw Shifter ThaBear14 2005-2010 Mustang GT 21 08-05-2009 03:44 PM
shifter knob and short throw shifter help blue-saleen Pre-2005 V6 Mustang 7 05-19-2009 07:52 PM
Short Throw Shifter? fasternu_674 Pre-2005 V6 Mustang 15 08-23-2007 08:52 PM
Short-Throw Shifter for under $10!!! drummerstang98 The Bar 7 09-28-2004 05:09 PM
Anyone with a short throw shifter? PureVenom The Bar 1 08-24-2004 11:12 AM
12:21 AM
