1996 GT AXLE CODE? - Mustang Evolution
Old 08-06-2009, 01:32 PM   #1
1996 GT AXLE CODE?
Its an "E" any one know what I have?
BILLFORD01 is offline   Reply With Quote
Old 08-06-2009, 02:30 PM   #2
Re: 1996 GT AXLE CODE?
if its stock its 2.73 rear gears, 8.8 axle
Old 08-06-2009, 02:32 PM   #3
the Factory sticker say it has an upgraded rear axle. so Im thinking it has trac loc rearend but I'm not sure what ratio. ware can I find the code defination.
Old 08-06-2009, 02:36 PM   #4
GT's came with T-lok already. There should be more numbers on the tag on the rear diff that will give you the gear ratios. However, if the gears have been swapped, odds are there won't be an indicator.
Old 08-06-2009, 02:37 PM   #5
nope all stock.
Old 08-06-2009, 02:42 PM   #6
Then there should be a metal tag on your rear diff with some numbers on it. Some of those numbers will give you the diff ratio.
The E you speak of, where did you pull that from?
Old 08-06-2009, 02:43 PM   #7
from the tag inside the driver door jam. it gives an axle code, paint code, ect....
Old 08-06-2009, 02:50 PM   #8
Y is the code for a non limited slip 3.08 axle
Z is the code for a limited slip 3.08 axle
5 is the code for a non limited slip 3.27 axle
E is the code for limited slip 3.27 axle.
GT 5speeds got 3.08s and GT autos got the 3.27's apparently... you learn something new every day
most dont know about the 3.08 gear option upgrade they had for a few year.
Old 08-06-2009, 02:53 PM   #9
mine is a 5 speed!! so your saying i have a limited slip 3.27 axle?
Old 08-06-2009, 02:56 PM   #10
Based on his info above...yes.
Old 08-06-2009, 02:57 PM   #11
hmm going by what ive read, its not possible to have 3.27s in a manual 96 gt... but most only mentioned 94/95 so they MAY have offered it for manuals in 96. Not much info out there for that.
You can look for a little tag on one of the bolts on the rear end cover, turn your wheel all the way one revolution and count your drive shaft rotations, or pop the rear cover lol to be 100% sure
Old 08-06-2009, 06:47 PM   #12
i dont think 94-95's ever came with 3.27's mine had 2.73's
iamdat is offline   Reply With Quote
Old 08-07-2009, 08:13 AM   #13
my stock 96 gt had a limited slip with 2.73
jk7208 is offline   Reply With Quote
Old 08-07-2009, 08:14 AM   #14
my stock 96 gt had a limited slip with 2.73 5 speed
Old 08-07-2009, 01:56 PM   #15
apparently manuals had an option for 3.08s and autos 3.27s~ most seem to not know about it.
Kind of like new gts can be had with diff gear ratios most dont know that
Old 08-08-2009, 12:16 PM   #16
hmm interesting
10:11 AM
