Burn out-traction control? - Mustang Evolution
Old 08-10-2009, 07:10 PM   #1
occhopperman27's Avatar
When i burn out after it gets wound up it like de-powers the motor, i have traction control with automatic
occhopperman27 is offline   Reply With Quote
Old 08-10-2009, 07:14 PM   #2
Re: Burn out-traction control?
Turn it off?
19Delta is offline   Reply With Quote
Old 08-10-2009, 07:28 PM   #3
That's the traction control hard at work...it has abs sensors that monitor the drive wheels. When one is spinning faster than the other one, ignition spark is retarded and the a/f is modulated. If it continues to happen (like when doing a burnout) it starts shutting down cylinders, applies brakes to the lower friction wheel, and give power to the other wheel.
Old 08-14-2009, 12:38 PM   #4
1998gt's Avatar
you turn the traction control off to get the most out of your burnout with it on just like sonicpony03 said it applies brake friction and stops your burnout!
1998gt is offline   Reply With Quote
Old 08-14-2009, 12:47 PM   #5
redcobravert's Avatar
Originally Posted by 19Delta View Post
Turn it off?
What he said
redcobravert is offline   Reply With Quote
Old 08-15-2009, 09:54 AM   #6
If i shut off the traction controll then only one back wheel spins?
Old 08-15-2009, 10:02 AM   #7
the traction control is nearly worthless on those cars leave it off unless in the rain
Old 08-15-2009, 10:34 AM   #8
Keto77's Avatar
I had a 2003 z06 vette u want to talk about something that would piss you off every time you shut the car off the TC would come back on .. go to burn them off and have it fall on its face in front of a crowd of people lol
1998 GT, 5 speed, Built by Anderson Ford, PI Heads , Intake , lowered 2 In , 3.73 Gears , BBK under drive pulleys, air sensor, k&n cold air, 75mm trick flow throttle body, Bassani exhaust, Hurst short throw shifter, Steeda high flow fuel pump , 24 lb injectors, Comp Cam slotted rotors, Mach 1 chin spolier
Keto77 is offline   Reply With Quote
Old 08-15-2009, 10:03 PM   #9
You had a z06 vette, why'd you get rid of that?
Old 08-16-2009, 12:06 PM   #10
If you turn it off and then the car off it will come back on just like that z06
Old 08-17-2009, 12:42 AM   #11
OsirisGuy's Avatar
Do you have a V6 or GT? The GT should have a TLock on it making both wheels spin.
If you have a V6 then only one wheel will spin.
There is a way to solve this though which is to get a new rear end and is a very common mod for V6 modders. By getting a TLock for the car you will get power to both wheels. If you really want to do the right thing you can save up a little extra and get an 8.8 rear end and go, with an automatic transmission, 4.10 gears.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 08-17-2009, 01:15 PM   #12
Keto77's Avatar
I go through alot of stuff get bored fast , got an 03 r1 for sale if anyones lookin for a bike.
Old 08-17-2009, 01:56 PM   #13
my TC comes on every time I start the car
Old 08-17-2009, 06:50 PM   #14
How many miles? That's a 1000cc right? (don't mean to hijack the thread )
Old 08-17-2009, 07:48 PM   #15
gt v8 auto both wheels spin with traction controll on 2 wheels spin with it turned off one wheels spins.
Old 08-17-2009, 08:29 PM   #16
That doesn't make any sense, either way both wheels should spin...the only thing I would say is that your tlok is worn out and needs to be rebuilt. The clutch pack is probably worn out, might have to replace it with some carbon discs like in the cobras.
Old 08-17-2009, 09:05 PM   #17
yes, its yamaha's 1 liter offering
ThaWill is offline   Reply With Quote
Old 08-18-2009, 12:20 PM   #18
Keto77's Avatar
Yeah 1,000 cc leo devince full system and a gpr steering dampener 12,3xx miles , Black and silver I can email pics if you want to want to take over the thread..
Old 08-19-2009, 06:47 PM   #19
Region: Nevada
If you have a diablo, you can have traction control switched off by default everytime you start the car.
chris098 is offline   Reply With Quote
Old 08-21-2009, 02:19 PM   #20
SaleenFiend's Avatar
Yea, it's a safety issues that vehicles must instate. TC has to turn back on everytime the vehicle is started. The only way to disable that function is through a tuner such as:
BTW any pics of the R1, I am currently tossing around the idea of a street bike and up to some ideas.
Traction control? braumab General Mustang Discussion 30 12-21-2007 01:50 PM
Motor acts like traction control is active ArmyStangGT 1996-2004 Mustang GT 6 09-29-2007 10:42 PM
ABS and Traction control light on rugman1969 1996-2004 Mustang GT 1 09-30-2006 03:09 PM
Traction Control Q wrecked2001 Pre-2005 V6 Mustang 12 03-20-2006 05:57 PM
traction control greenpony02 Pre-2005 V6 Mustang 28 05-02-2005 09:57 PM
08:37 AM
