changed gears yesterday 3.73 to 4.10 - Mustang Evolution
Old 08-12-2009, 06:09 AM   #1
Keto77's Avatar
not sure if i like it or not , was getting some noise from my rear end and we swaped rear ends they said id be a lil faster on low end with the 4 10 kinda seems i lost some mid range power though..
1998 GT, 5 speed, Built by Anderson Ford, PI Heads , Intake , lowered 2 In , 3.73 Gears , BBK under drive pulleys, air sensor, k&n cold air, 75mm trick flow throttle body, Bassani exhaust, Hurst short throw shifter, Steeda high flow fuel pump , 24 lb injectors, Comp Cam slotted rotors, Mach 1 chin spolier
Keto77 is offline   Reply With Quote
Old 08-12-2009, 09:50 AM   #2
Re: changed gears yesterday 3.73 to 4.10
you just go through the power band much faster, 4.6 like higher rpms generally speaking
Old 08-13-2009, 11:05 AM   #3
Keto77's Avatar
so would you use the 4 10 or the 3 73 ?
this is not my D.D . so it only gets drivin in town most of the time , looking more for low end and mid range pull
Old 08-13-2009, 10:00 PM   #4
redcobravert's Avatar
you may have and u get worse gas mileage
redcobravert is offline   Reply With Quote
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Postbit Changed Brent ME Site Help & Announcements 22 09-15-2007 08:38 PM
KNyTeKr3X (We changed the name.) Dom The Bar 17 03-10-2004 09:26 AM
Somethings changed.... 98GreenStallion The Bar 10 10-30-2003 06:31 AM
Is it expensive to get gears changed on an automatic tranny? DropTop_Stang Pre-2005 V6 Mustang 19 08-23-2003 01:36 PM
» Members Mustangs
mustang
svo
Steve96
Add your Mustang
04:25 PM
