i need ideas for 1998 gt - Mustang Evolution
Old 08-12-2009, 07:32 PM   #1
1998gt's Avatar
Smile i need ideas for 1998 gt
i have a 1998 gt all stock i just got it and im just starting to build it up. im only 16 so i have a low budget. i cut the mufflers off and got single pipe put in for my low budget exhaust and my neighbor gave me his old k&n air filter. what is the next thing i can do to add more hp at a low budget? thanx
1998gt is offline   Reply With Quote
Old 08-12-2009, 11:06 PM   #2
upton7's Avatar
Re: i need ideas for 1998 gt
Well you haven't gained hardly any at all which i'm sure u can tell. The filter alone won't do much u want the entire intake. And well here is the average list. 3.73 gears upgraded exhuast and intake. Underdrive pulleys maybe. port and polish and gasket match. Short throw shifter. Decent tires if you tread is almost bare. Since you have a 98 i'd try to get some salvage pi heads of a 99-04. And the intake manifold and cams if it is in the budget. It is all about the money you have and the people you know.
Old 08-13-2009, 08:06 AM   #3
save up for a catback and mac prochamber or something similar. After that I would lower it with wheels/tires
then do a PI head swap because that care NEEDS some power desperately and that will boost you to about 285 from 215 at the engine for pretty cheap.
Old 08-13-2009, 11:04 AM   #4
Keto77's Avatar
See Below I have a 98..
1998 GT, 5 speed, Built by Anderson Ford, PI Heads , Intake , lowered 2 In , 3.73 Gears , BBK under drive pulleys, air sensor, k&n cold air, 75mm trick flow throttle body, Bassani exhaust, Hurst short throw shifter, Steeda high flow fuel pump , 24 lb injectors, Comp Cam slotted rotors, Mach 1 chin spolier
Keto77 is offline   Reply With Quote
Old 08-14-2009, 08:59 AM   #5
1998gt's Avatar
hey thanks! your car is built pretty much how those guys were saying to build it up to. wat does the short throw shifter do for you?
Old 08-14-2009, 09:01 AM   #6
1998gt's Avatar
hey thank you for your suggestions! my neighbor has an 04 cobra and he said i should save for a catback exhaust also. but he said lowering it would only be cosmetic it really wouldnt help me in any way?
Any ideas????? 499CSTANG The Bar 15 04-28-2010 11:45 PM
ideas? Kryptonite Mustang Audio & Video 2 10-23-2006 02:49 PM
any more ideas? machoman013 Pre-2005 V6 Mustang 1 08-14-2006 07:57 AM
ideas blue00v6 Pre-2005 V6 Mustang 13 04-28-2006 10:01 AM
Ideas??? 1Slow6er Mustang Audio & Video 3 05-01-2003 10:08 PM
05:06 AM
