Help Asap Please!! - Mustang Evolution
Old 05-16-2005, 08:17 PM   #1
douGT's Avatar
Help Asap Please!!
I just installed my Accufab 75 TB & P, could you guys tell me how to fix my idle control. they gave me a tiny little piece of paper saying only adjust it by adjusted the throttle postion sensor. if you guys could tell me how adjust it and where this is, i would GREATLY apprecticate ASAP PLEASE!!!
douGT is offline   Reply With Quote
Old 05-17-2005, 11:03 AM   #2
Well you loosen the screws holding the TPS on and move it ever so slightly if you can but first make sure you have the IAC on the correct way. Does it make a sound like a moose? If so its on backwards.
96 GT 4.6 L
Ported 2004 Upper Plenum
B&M Shifter
Bassini O/R X Pipe
FRPP Adjustable Clutch Cable
UPR Extreme Triple Hook Quadrant
UPR Extreme Firewall Adjuster
Ford 11"Clutch Conversion
C&L MAF
WMS CAI
Aluminum Drive Shaft
95 V6 Vert: 4.2L swap, Trac Lock, Light Cam, Mac Shrorty Headers, More to come.
AlmostN8 is offline   Reply With Quote
Old 05-17-2005, 08:21 PM   #3
douGT's Avatar
no, its not on backwards, it all came all together from the factory. im taking it at a shop tomorrow, just to see waht they say. When i push the clutch in, my rpm's go to 2000 and sit there for about 20-30 seconds roughly, then drop back down to idle. in between shifts, my rpm's go up and stuff like taht, its like my butterfly is staying open a little. so, im takin it in tomorrow to get it checked out sense i don't know how to drop it back down
Need help asap buddykern 1996-2004 Mustang GT 18 11-25-2009 06:52 PM
NEED HELP ASAP!!!!!!!! sledgehammer Pre-2005 V6 Mustang 4 03-29-2008 08:57 PM
need help asap reaper4stang Pre-2005 V6 Mustang 16 08-28-2005 12:30 PM
Need help asap Brent Pre-2005 V6 Mustang 7 05-22-2005 08:53 AM
need help asap!!! Monkey Pre-2005 V6 Mustang 17 06-20-2004 11:24 PM
07:04 PM
