I need some help with my Mustang!!! - Mustang Evolution
Old 08-14-2009, 01:06 PM   #1
ok i got this mustang about a week ago and here is what has been done to it before i got it. The body is a 1995 v6, the engine is a 98 4.6l gt and it has a procharger on it. As far as engine mods it has the pro charger a 75mm throttle body a 90mm SCT senors, Ford racing heads,12lbs pulley giving it 12lbs of boost, its runing on 32lbs injectors and it all so has the 2:55 fuel pump. It has the stock v6 suspension set up on it. the rear end is a 8:8 gt rear end. the guy i got it from had it dynoed and it put 425 hp to the wheels
Here are the ?'s i have. The mustang wants to keep dying on me when i come to a complete stop like at a red light. I dont know if i need bigger feul injectors or if it just needs to be tuned. I was thinking about changing to a 10lbs pulley and seeing if that would help. Then what kind of suspension should i put under it? And i dont know what gears to put in it i was thinking 4.10 gears if anyone can help me a really appreciate it thanks
1995procharged is offline   Reply With Quote
Old 08-14-2009, 04:49 PM   #2
upton7's Avatar
Re: I need some help with my Mustang!!!
3.73 gears
Eibach springs or h&r
Bilstien if you got the cash
mm subframe connectors
If lowered mm caster cambers
Old 08-14-2009, 04:55 PM   #3
SVTCOBRA's Avatar
This Mustang automatic or manual?
SVTCOBRA is offline   Reply With Quote
Old 08-14-2009, 09:06 PM   #4
sounds like you need a tune asap. might want to put a wideband on also. a 255 might not be up to snuff for the power you're putting down. be worth checking to protect your investment
iamdat is offline   Reply With Quote
Old 08-15-2009, 03:18 AM   #5
its a manual
Old 08-15-2009, 12:48 PM   #6
1998gt's Avatar
maybe think about getting a short throw shifter!
1998gt is offline   Reply With Quote
Old 08-15-2009, 04:29 PM   #7
You need to Dyno your car and get the rpm up higher to 1,000 rpm at nuetrual. you can do this with a regular tuner also. but be careful how you do this. And for the 4.10 gears will be nice though you will get more torque plus hp and you will lose gas more.
tjzola is offline   Reply With Quote
Old 08-15-2009, 07:01 PM   #8
upton7's Avatar
Gears don't add any horsepower.
Old 09-01-2009, 09:11 PM   #9
occhopperman27's Avatar
Bilstien shocks are the way to go, it may need a tune-up, plugs, wires ect...
occhopperman27 is offline   Reply With Quote
11:26 PM
