Surging idle - Mustang Evolution
Old 08-14-2009, 11:41 PM   #1
Keto77's Avatar
Surging idle
For some reason my car seems to surge a bit when I come to an idiol used to drop a lil hunt around for a sec and then even out, but tonight it died like three times , I was kinda thinking the tpi sensor ? any other thoughts and if it was the sensor wouldent I have probs at higher rpms , it only does it at and idiol the other thing is when i rev it up it take a few secs to come back to a normal idiol it seems to hold the rpms high for to long.. What do you Think ?
1998 GT, 5 speed, Built by Anderson Ford, PI Heads , Intake , lowered 2 In , 3.73 Gears , BBK under drive pulleys, air sensor, k&n cold air, 75mm trick flow throttle body, Bassani exhaust, Hurst short throw shifter, Steeda high flow fuel pump , 24 lb injectors, Comp Cam slotted rotors, Mach 1 chin spolier
Keto77 is offline   Reply With Quote
Old 08-15-2009, 12:13 AM   #2
Re: Surging idiol
o2 sensor maybe? other than that I wouldn't have any idea.
19Delta is offline   Reply With Quote
Old 08-15-2009, 03:10 AM   #3
Tape's Avatar
Re: Surging idiol
the IAC controls the idle, remove it and clean it with carb cleaner, this may work but others reported it didn't for them. O2's will mess with your idle as well but usually with a cel
Tape is offline   Reply With Quote
Old 08-15-2009, 09:36 AM   #4
Keto77's Avatar
Re: Surging idiol
ok thanks will give it a try..
Doesn't idle down. Joe_SHO Pre-2005 V6 Mustang 7 02-12-2009 07:44 AM
rough/surging idle dragonlouie 1979-1995 Mustang GT 25 08-23-2008 07:59 PM
Stumbling and surging dancoy2000 1996-2004 Mustang GT 3 02-25-2008 10:47 AM
Bad Idle JustlikeaFox 1979-1995 Mustang GT 1 11-22-2006 03:52 PM
At idle ASSEMbler Pre-2005 V6 Mustang 14 08-07-2003 01:54 AM
10:38 PM
