4.6L engine ?'s - Mustang Evolution
Old 08-17-2009, 09:15 AM   #1
4.6L engine ?'s
Im needing some help building my engine up. I really have no idea what i need to do or order parts wise. The reason im asking is because i have a procharger running 12lb of boost on a stock 4.6 motor and everyone i have talked to is telling me I need to build the engine because there worried ill blow the bottom end out of it. i would greatly appreciate the help
1995procharged is offline   Reply With Quote
Old 08-17-2009, 09:43 AM   #2
hottcobra's Avatar
Re: 4.6L engine ?'s
New - Livernois Motorsports - Home
these guys build tons of motors
Old 08-17-2009, 11:04 AM   #3
redcobravert's Avatar
Re: 4.6L engine ?'s
if you want big numbers turbos are the way to go check out this built 2v 4.6
redcobravert is offline   Reply With Quote
Old 08-17-2009, 12:10 PM   #4
Re: 4.6L engine ?'s
the 4.6L from 98 gt's will hold about 400rwhp maybe 450 (its all in the tune) and about 10-12psi~ so you are at the limit. Basically if you dont have a custom (good quality) dyno tune (not just the chip that comes with the procharger) you are a ticking time bomb.
Old 08-17-2009, 04:24 PM   #5
Re: 4.6L engine ?'s
yea that was what i was thinking. The guy i got the car from said the last time it was tuned was a year and a half ago. I just ordered a 10lb pulley to lower the psi were it wouldn't put as much pressure on the engine cause i dont wont or have the money to replace the bottom end. There is a shop im taking it to next week its called Ford Performance Specialsits Inc.
Ford Specialists.com - Ford Performance Specialists
they specialize in fords, they gave me a price of $900 to test and tune the whole nine yards but i thought it was kinda high but i need it done bad
Old 08-17-2009, 07:43 PM   #6
Re: 4.6L engine ?'s
if you are looking for another motor to handle boost, i would look into MMR. they are reknown in the mod motor world and they are currently having a sale on their shortblock assemblies.
96 GT- Who knows what's in it.
Old 08-20-2009, 03:29 AM   #7
2007STANG's Avatar
Region: West Virgina
Re: 4.6L engine ?'s
if you look at the procharger web site they run alot cooler because its a belt driven with a two or three stage inner cooler if it the one you have spec'ed for your car then there should be no problem from what i've read if you changed the pully size on the procharger then i would worry
http://www.procharger.com/2005_mustang.shtml
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 08-20-2009, 07:56 AM   #8
Re: 4.6L engine ?'s
anytime you modify the boost you have to check the tune, it needs to have a save A/F across the board.
POSSIBLE NEW ENGINE upton7 1996-2004 Mustang GT 19 06-13-2009 04:06 AM
V6 Engine Help kack85 Pre-2005 V6 Mustang 3 01-08-2009 09:37 PM
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 07:40 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
06:30 AM
