INPUT SHAFT!!! - Mustang Evolution
Old 08-19-2009, 02:04 PM   #1
redcobravert's Avatar
INPUT SHAFT!!!
These pics are from last year has anyone else done this before?
redcobravert is offline   Reply With Quote
Old 08-19-2009, 02:05 PM   #2
Re: INPUT SHAFT!!!
I didn't break mine, but I did swap mine out to a 26 spline before it could break on me. Still have my 10 spline at the house.
Old 08-19-2009, 02:12 PM   #3
Re: INPUT SHAFT!!!
Nice i ended up just replacing it with another 10 spline i found on ebay for 50 bucks cause i didnt want to replace the clutch
Old 08-19-2009, 02:15 PM   #4
Re: INPUT SHAFT!!!
yup input shafts break on the 03/04s most upgrade when it happens
Old 08-19-2009, 02:20 PM   #5
Re: INPUT SHAFT!!!
this was my mistake i was running a c5 zo6 and threw it in 2nd instead of 4th at about 105mph i heard a little chirp from the nittos and that was the end of it LOL
Old 08-19-2009, 06:15 PM   #6
hottcobra's Avatar
Re: INPUT SHAFT!!!
well I guess you didn't upgrade before or it could've been the motor and not the shaft.
Old 08-20-2009, 06:18 PM   #7
Re: INPUT SHAFT!!!
Put a 26 spline in when upgrading everything else....and that's the reason lol.
It's not bad till you're snapping 26 splines like that...had a friend do it.
Old 08-21-2009, 09:57 AM   #8
Re: INPUT SHAFT!!!
its kind of a pain to put an inputshaft in isnt it?
Old 08-21-2009, 10:16 AM   #9
Re: INPUT SHAFT!!!
Not really. Once you have the trans out you take out a few bolts and the front cover comes right off. Then, swap shafts. The only hard part is finding the proper sized shim to get the free play in spec. I was lucky and grabbed the proper one first try.
Old 08-21-2009, 04:08 PM   #10
SaleenFiend's Avatar
Re: INPUT SHAFT!!!
Yep!
BTW I had a bad downshift a few weeks ago! I bout **** my pants b/c I was just waiting on the splines to tear up! or as Louis said...Motor
Old 08-22-2009, 12:42 AM   #11
Tape's Avatar
Re: INPUT SHAFT!!!
at least you know your clutch is grabbing.
Tape is offline   Reply With Quote
Old 08-22-2009, 04:25 PM   #12
Re: INPUT SHAFT!!!
I brought it to a transmission shop and i think i payed under $180 to have it replaced
Old 08-23-2009, 01:59 PM   #13
Re: INPUT SHAFT!!!
I pulled my trans and dropped it and the new shaft off at a shop for an afternoon. He didn't have time to get to it so I ran by the next morning to pick it up. He said he had forgotten and pulled the cover, popped the old one out, set the new one in, shimmed it up right and I was out the door in 15 minutes.
The trick I kept forgetting was to stand the transmission on it's end when setting everything back together, I had the forks all screwed up doing it myself.
Aluminum Drive Shaft? Paincake1 Pre-2005 V6 Mustang 5 01-22-2009 05:41 PM
Have You Broken Your TREMEC Input Shaft? jwyche 1979-1995 Mustang GT 0 11-09-2008 10:52 AM
FS: NEW IN BOX Drive shaft loop Loco Mustang Parts for Sale and Wanted 0 11-27-2005 09:05 AM
stock mustang cam shaft? bigpomps Pre-2005 V6 Mustang 3 03-15-2005 01:02 PM
check out my shaft (not that kind you perv) fast64 Pictures and Videos 5 10-21-2004 09:39 PM
11:02 AM
