03 GT Misfire - Mustang Evolution
Old 08-22-2009, 10:23 PM   #1
03 GT Misfire
I have researched some previous posts and tried a few things but nothing has worked yet. I have a mostly stock 03 gt. I have added a ford racing 70mm throttle body, 75mm trickflow plenum, K&N cai, and a Diablo tuner. The problem started small and has progressively gotton worse. The car feels like it's sputtering and only when crusing at a consistent speed and only some times. I can't feel it when accelerating but I can tell the performance isn't there. I have installed all new plugs, coil on plugs, dpfe egr sensor, and fuel pump. I was thinking injectors next but I hate to spend any more money on something that wont cure the problem. Any suggestions on what to check would be appreciated.
finallyaGT is offline   Reply With Quote
Old 08-23-2009, 10:43 PM   #2
Re: 03 GT Misfire
Well I changed the plugs again and went back to stock motorcraft. I drove to work today and just got home and the missing is gone.
Old 08-23-2009, 11:45 PM   #3
iwannagofast's Avatar
Re: 03 GT Misfire
i got the same problem right now. so it was the coil packs?
iwannagofast is offline   Reply With Quote
Old 08-24-2009, 07:13 AM   #4
Re: 03 GT Misfire
vacuum leak?
Old 08-24-2009, 12:02 PM   #5
Re: 03 GT Misfire
iwannagofast it was the spark plugs. When I first felt the motor starting to miss I tried the zex spark plugs but the problem continued. I then bought the coil onplugs but that didn't cure the problem either. So long story short I tried the stock motor craft plugs and now it's running great. I had planned on changing out the coil on plugs anyway but I was guessing with everything else. On the bright side I now have some new parts that I shouldn't have to worry about for a while. I thought it could be a vaccul leak like suggested so I bought a cheap cigar and checked for vaccum leaks by blowing small streams of smoke along the vaccum lines. Seamed like a good idea and like former president I didn't inhale either. Try new plugs first and .buy the motor craft
Old 08-24-2009, 04:54 PM   #6
Tape's Avatar
Re: 03 GT Misfire
when you change the plugs change the boots as well, I've had the same issue twice and both times it's been the boots. they're about 6$ea so people tend to avoid them, but they have a lifetime warranty if you goto autozone, I change my boots when I change the plugs and haven't had those problems since.
Tape is offline   Reply With Quote
Old 08-24-2009, 05:25 PM   #7
Otlaw80's Avatar
Re: 03 GT Misfire
Motorcraft/autolite are the best damn plugs you can buy for anything. And i'm not just saying that cause they are ford. Never had a problem with them, I have with most other brands except.
Old 08-26-2009, 01:11 PM   #8
Re: 03 GT Misfire
one of my injectors were unplugged, easy and cheap fix. jus how i like it
Misfire ??!! English Paul General Mustang Discussion 7 11-10-2009 12:18 AM
Another misfire 2000MustangGT17 1996-2004 Mustang GT 5 06-24-2009 08:47 AM
#1 misfire 2kslvrgt 1996-2004 Mustang GT 4 02-17-2009 01:26 PM
another misfire! Jeremym831 1996-2004 Mustang GT 4 03-03-2008 10:01 AM
misfire in #1 vramos1 Pre-2005 V6 Mustang 4 09-15-2007 02:24 PM
10:23 PM
