a/c idle problems - Mustang Evolution
Old 08-25-2009, 07:05 PM   #1
upton7's Avatar
a/c idle problems
When i turn on my a/c at max ac and 2 the fourth dot and i'm idling my tach needle will go up and down then go down and die but if i turn it off or lower it will be fine. Whats goin on here?
Old 08-25-2009, 08:28 PM   #2
occhopperman27's Avatar
Re: a/c idle problems
idle air control, probably, napa, car quest, have them for under 100 $
occhopperman27 is offline   Reply With Quote
Old 08-25-2009, 09:15 PM   #3
upton7's Avatar
where is that located on the car
Old 08-26-2009, 10:17 AM   #4
SaleenFiend's Avatar
Its located on the throttle body of the vehicle. Not the TPS.
Old 08-26-2009, 06:52 PM   #5
upton7's Avatar
that decently sized black hose?
Old 08-26-2009, 07:19 PM   #6
Old 08-26-2009, 09:03 PM   #7
upton7's Avatar
Thank you sir how do i remove and replace?
Old 08-27-2009, 08:00 AM   #8
Should have two 8 or 10mm bolts that hold it down and a gasket. You could start by getting some carb cleaner and trying to clean it out, but it will more than likely be bad.
BTW I don't really know if this is the issue at all. It could be your A/C fan clutch or condensor. I would check it out first. I was only showing you where the IAC was.
Old 08-27-2009, 11:44 PM   #9
upton7's Avatar
I'm gonna try and clean it and see if that does nething shouldn't take too long or cost hardly anything to try.
Idle Problems on warm motor in Park? 91StangGT5.0 1979-1995 Mustang GT 2 03-05-2010 11:50 PM
Idle Problems and Gas milage dacoday 1996-2004 Mustang GT 2 11-10-2009 07:41 AM
Idle Problems??? Special K 1996-2004 Mustang GT 12 03-01-2007 01:34 PM
At idle ASSEMbler Pre-2005 V6 Mustang 14 08-07-2003 01:54 AM
CAI installed... low idle problems... RedStang830 Pre-2005 V6 Mustang 16 08-03-2003 08:33 PM
07:58 PM
