Yup, more v6 to 4.6 swap questions - Mustang Evolution
Old 06-06-2005, 03:20 PM   #1
fast64's Avatar
Thinking about doing the swap that so many people ask about. I know it would usually be cheaper to just sell the v6 and buy a gt, but it will be cheaper in this case because I might be getting a 95 v6 rolling chassis and a totalled 97 gt.
Did anything change between the v6s from 94-95 and 96-98? Is the fuel system on the v6 a return or returnless system? how about on the 4.6? Other than that I think I got everything covered.
GO BRAVES
Old 06-07-2005, 08:07 AM   #2
Danger Dude's Avatar
The fuel pump is different between 94-97 and the 98 The the 98 has the same pump as the GT and in 94-97 it was smaller. Returnless did not come out till 99
Old 06-07-2005, 08:41 AM   #3
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
Get some PI heads and intake if your going to do it and get it all done at the same time.
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 06-07-2005, 12:49 PM   #4
Crossmember is different. You'll need a tubular. Wiring harneses are all different. Basicly get ready to move everything electrical over with the engine. Tranny mounts are different lots of stuff really.
96 GT 4.6 L
Ported 2004 Upper Plenum
B&M Shifter
Bassini O/R X Pipe
FRPP Adjustable Clutch Cable
UPR Extreme Triple Hook Quadrant
UPR Extreme Firewall Adjuster
Ford 11"Clutch Conversion
C&L MAF
WMS CAI
Aluminum Drive Shaft
95 V6 Vert: 4.2L swap, Trac Lock, Light Cam, Mac Shrorty Headers, More to come.
AlmostN8 is offline   Reply With Quote
Old 06-07-2005, 12:55 PM   #5
fast64's Avatar
i knew all that stuff, just wasn't sure on the fuel pumps, if i get these cars i'll probably just swap fuel tanks.
GO BRAVES
Old 06-11-2005, 11:47 AM   #6
silverstangboy's Avatar
I hate to refer you to somewhere else, but they're are many people that have done this already that are definely willing to help you.. not to meantion that doing a search on a few popular websites will help also, ME is still very new in the V8 attention department
93 mustang notch
~450hp 331 stroker - Sold
Old 06-11-2005, 02:09 PM   #7
I'd reccomend to try to find a donor car from the same year or atleast that has the same basic parts as yours.
If they changed the crossmember, ecu, fuel, wiring and whatnot between your car and the donor car you will have a lot to change over....if you find one with the same basic stuff and just need to convert some wiring and other smal things, get that.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 06-17-2005, 06:43 PM   #8
fast64's Avatar
swapping the running gear from any gt into any v6 will involve swapping all that stuff. it shouldnt be any harder than the swap in the 64; it will probably be easier since its mostly unbolt from the gt, bolt into the v6
GO BRAVES
Old 06-17-2005, 08:11 PM   #9
Rick0636's Avatar
Yeah man, it will be an adventure, but if you go lots of time and doing most of it yourself, I imagine you can do it just fine, take your time, read the haynes manuals and everything else you can find about it. A PI head swap would not be a bad idea while you have that 4.6L out of the car if you can afford it. And of course the intake to go with it.
Old 06-19-2005, 01:29 PM   #10
Rick0636's Avatar
Here is a good trick to remember to tell if you have bad wires. Stop your car in a very dark place at night and raise the hood, if you have bad wires, they arch to surrounding metal objects, so if they are bad you will see a small light show around them under the hood in the dark.
Old 06-19-2005, 01:30 PM   #11
I liek gramer
WhiteStang99's Avatar
^ huh. good advice, I'd have never thought about that. Of course, I can't think of any dark place in Birmingham I'd want to stop my car at....
Split port swap questions big show 98 Pre-2005 V6 Mustang 13 01-09-2010 02:27 PM
7.5 to 8.8 rearend swap questions... strawdog Pre-2005 V6 Mustang 6 06-18-2009 03:11 PM
swap questions ryanxup Pre-2005 V6 Mustang 10 01-27-2007 11:02 AM
I have a couple 5.0 swap questions colinsv6stang 1979-1995 Mustang GT 5 04-28-2006 12:18 PM
Gear and axle swap questions. DarkShadow Pre-2005 V6 Mustang 15 09-07-2005 02:18 AM
11:53 AM
