Idle is just getting worse - Mustang Evolution
Old 09-02-2009, 06:01 PM   #1
Okay, I cleaned the MAF sensor, the IAC sensor, and I am about to go buy a couple of new hoses for it, if this doesn't work I don't know what else to do. I guess that means I am going to be forced to buy either a new MAF or IAC, but how do I know which one? I don't feel like throwing money into it anymore if its not going to fix it. Any ideas?
katie_ann is offline   Reply With Quote
Old 09-02-2009, 08:53 PM   #2
silverstangboy's Avatar
Re: Idle is just getting worse
throwing any codes?
check simple stuff first, plugs, wires?
mine once filled with water on a 96 4.6 around the boot on the spark plug, would occasionally short to ground... I replaced coils before I found it :dummy:
93 mustang notch
~450hp 331 stroker - Sold
Old 09-03-2009, 08:04 AM   #3
will spark plugs cause it to idle funny and cut out? and yes it threw up P1131 but I messed up and unhooked the battery after I cleaned the MAF sensor and the check engine light hasnt come back on.
Old 09-03-2009, 04:26 PM   #4
Check your other thread, I answered your question. Problem solved.
Can't imagine much worse... MarkuzLS1 The Bar 10 11-14-2007 03:28 PM
Iraq about to get worse? MarkuzLS1 The Bar 5 10-09-2007 11:16 AM
From Good To Worse bluemustang The Bar 6 06-27-2007 08:54 AM
Cause 2006 couldn't get any worse meteorachick The Bar 13 12-11-2006 11:32 AM
as if cali cant get any worse! Thomas91169 The Bar 6 06-15-2006 08:41 AM
12:14 AM
