Changing front bushings: how to? - Mustang Evolution
Old 09-10-2009, 08:09 AM   #1
DarkShadows's Avatar
ok well me and some racing buddies have come to the conclusion that i need to change my front control arm bushings on the stang. i have 2 1/2 degrees of negitive camber and i still roll on to the outside of the tire. like this
so anyway i want to use the MM bushing kit, so my question is how hard are these to change, what is the procedure to do this? thanks for all yalls help in advance
March 2010 Mustangevolution Mustang of the Month 1st eva biatch!
DarkShadows is offline   Reply With Quote
Old 09-10-2009, 08:09 AM   #2
Re: Changing front bushings: how to?
o and by the way before someone said i didnt have enough air in the tire, i had 38psi in the tire in that pic
Old 09-10-2009, 08:15 AM   #3
hottcobra's Avatar
not really that hard. you just have to remove the control arms and press the old bushings out and press the new ones on. and by press I mean beat them with a hammer.
now If you need directions on how to remove the control arms just let me know. also you will need to realign the car after this.
Old 09-10-2009, 08:46 AM   #4
If you are going to do it, i would recommend getting 03/04 cobra A Arms as they are setup differently and handle better. I would go Delrin only NOT URATHANE
Old 09-10-2009, 10:33 AM   #5
why go with the delrin over the ureathine?
Old 09-10-2009, 10:34 AM   #6
aligment will not be a problem as i have lifetime aligments at the place i use
Old 09-10-2009, 11:14 AM   #7
OsirisGuy's Avatar
I don't think getting to the bushings is all to hard. But to replace them, well vice clamps and C-clamps may be your friend as well as a little enginuity.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 09-10-2009, 10:20 PM   #8
The reason for delrin over urethane is urethane will wear out like rubber will. Delrin are harder and will last longer than urethane.
Old 09-11-2009, 09:23 AM   #9
+1 Delrin is where its at, it costs more but is FAR better
read about it here Full Tilt Boogie Racing Homepage its mainly for IRS cars but it has good info.
Changing front blinker bulb? jmy2469 2005-2010 Mustang GT 8 06-04-2008 12:00 PM
Maximum Motorsports steering rack bushings fastmustangs1 Pre-2005 V6 Mustang 1 10-22-2004 05:16 PM
Cobra Front Brakes, MM Rack Bushings, and PICTURES added... Rick0636 Pre-2005 V6 Mustang 32 03-29-2004 09:46 AM
Cobra front brakes, MM rack bushings, and Pics ADDED Rick0636 Pre-2005 V6 Mustang 8 03-28-2004 10:39 PM
Bushings for lowering springs Blue232 Pre-2005 V6 Mustang 10 10-09-2003 01:33 PM
11:49 PM
