Oil changing questions. For a mod newb - Mustang Evolution
Old 06-23-2005, 11:25 AM   #1
Just changed my oil today. I went with motorcraft 5w-20 as per the manual. I wanted to go with mobil 1 synthetic but couldn't find it at 5w-20. Is mobil 1 a better oil to go with, performance wise, or will it not make much difference? Also, how many quarts does the 02 gt take? I know my 5.0 takes 5 quarts, is it the same?
2002 Mustang GT, 5-speed, torch red. K&N, 3.73 gears, flowmaster cat back, and lots of love.
1991 5.0 lx conv. auto, black. Full saleen body kit, cold air intake, msd ignition, flowmasters, off road h-pipe, underdrive pulleys, trickflow intake, trickflow stage 1 cam, 190 lph fuel pump, 30 lbs injectors, 73mm mass air.
http://www.mustangevolution.com/gall...0632_thumb.jpg
saleen0027 is offline   Reply With Quote
Old 06-23-2005, 11:47 AM   #2
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
My manual says 5 quarts but I've been told 6 so I think it varies from one model year to another. The motorcraft oil will be just fine. I like it as it's a quality synthetic that doesn't cost an arm and a leg
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 06-23-2005, 02:16 PM   #3
redfire2003's Avatar
Just wanted to let you know that I am a ford tech and the GT takes 6 quarts of oil.
redfire2003 is offline   Reply With Quote
Old 06-23-2005, 02:40 PM   #4
Rick0636's Avatar
It changed from 5 quarts to 6 quarts sometime during the 01 model year is what I was told in a similar thread not long ago.
Old 06-23-2005, 02:41 PM   #5
Rick0636's Avatar
Also if an oil does not say it is synthetic, it isn't, if it does, then it should be, I use Havoline Synthetic 5w-30 , 5w-20 is just a tad thinner.
Old 06-23-2005, 03:56 PM   #6
MonteCitan's Avatar
that change was made during the 02 model year.. mine was 6 quarts but my buddy's 02 is 5..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-23-2005, 09:42 PM   #7
01mineralgrey6's Avatar
mine is 6 qts too.
-Tony
'99 cobra 'vert
Old 06-23-2005, 09:47 PM   #8
What warranted the change? Bigger Oil pan?
Old 06-23-2005, 10:15 PM   #9
I run mobil1, only way to go for me.
Old 06-24-2005, 06:45 AM   #10
MonteCitan's Avatar
Yes, it was a running change
Old 06-24-2005, 10:00 AM   #11
I use mobile 1, if i was you I would also. Last time it ran me 23 bucks for everything which is cheap for the quality of oil you get. Yea they dont make 5w20 either, so I run 5w30... I think last time I went I did see some 5w20 so there may be hope, they may have started using it.
Old 06-24-2005, 10:23 AM   #12
Danger Dude's Avatar
In a 2 year study I analyzed several major oil brands synthetic and regular and found all synthetics to be a vast improvement over regular oil and the difference between synthetics to be more about price than any real difference in quality. Choosing any name brand synthetic will give good performance if you change it by 7000 miles regular driving and 5000 if you race or run your car hard and use a good filter as in Motorcraft or Fram. Spending money on some super fancy filter is also a waste.
I have used Mobil 1, Havoline Syn and Castrol synthetic and am currently using Castrol. I also use Motorcraft filter and will use Fram
Old 06-24-2005, 07:37 PM   #13
Walmart here runs a special on 5 quarts for 20 bucks, I stock up on those, use the regular fram filters, and change every 5k normally.
Old 07-15-2005, 12:58 PM   #14
Rick0636's Avatar
I had been changing around 5K, but wouldn't worry even if I ran up to 6K, I used the K&N oil filter which had gone up a couple of dollars last time I changed the GT, shortly before the wreck, if anyone gets my engine they will get a good one, it only had about 50K on it, probably not that and about half of that on synthetic Havoline.
Old 07-15-2005, 01:35 PM   #15
ford brand is semi syth. but I would run full synth from Moble 1, just run any full synth and you will be fine as long as its a name brand.
Old 07-15-2005, 01:50 PM   #16
Yeah, they do make it....but trying to find it is a *****. I have been running 20 in my car but I am switch to 30. Higher summer temps, and also higher boost temps. Going to go a little thicker with the next change which will be right after Jax.
Old 07-15-2005, 01:56 PM   #17
I went to their site and everything and they used to not make 5w20
Old 07-15-2005, 02:22 PM   #18
We started carring it at work a few month ago
-Tony
'99 cobra 'vert
Old 07-15-2005, 02:26 PM   #19
Actually The whole 5w20 was a mistake on the engineers and text writer with Ford. They screwed the pooch when they put in in text and some oil caps. Finding 5w20 a few years ago was as easy as finding big foot or the Loch Ness monster
Old 07-15-2005, 02:29 PM   #20
-Tony
'99 cobra 'vert
Old 07-15-2005, 02:32 PM   #21
I liek gramer
WhiteStang99's Avatar
so, uhh, what was it supposed to be?
Old 07-15-2005, 02:33 PM   #22
5w30
Old 07-15-2005, 04:56 PM   #23
I heard the EPA got down on ford and they swaped the oil to 5w20 to help emmisions, either way its not a big diff I run 5w30 and its fine.
Changing my blower oil, any tips SpectorV 1996-2004 Mustang GT 5 04-07-2006 12:22 PM
About changing oil... Ibanezplayer272 Pre-2005 V6 Mustang 21 02-23-2006 09:33 PM
Changing Oil Ques. douGT 1996-2004 Mustang GT 14 05-01-2005 07:55 PM
changing oil pickup, how to prime it? fast64 1979-1995 Mustang GT 4 04-21-2005 05:51 PM
Think changing your oil every 3k miles is good? Think again Monkey Pre-2005 V6 Mustang 14 02-24-2004 05:39 PM
12:42 AM
