Oil Change Help - Mustang Evolution
Old 07-21-2005, 10:40 AM   #1
Oil Change Help
I have a 1998 4.6L Stang. I need some help with the oil change and tune up. Does anyone have a post link they can send me to assist and/or some quick FYI's and pointers.
Thanks fellas!!
robert0803 is offline   Reply With Quote
Old 07-21-2005, 11:44 AM   #2
Err drain the oil, new filter and oil and change the plugs and wires. Thats about all thats needed. If you need a write up on those please take your car to be serviced.
96 GT 4.6 L
Ported 2004 Upper Plenum
B&M Shifter
Bassini O/R X Pipe
FRPP Adjustable Clutch Cable
UPR Extreme Triple Hook Quadrant
UPR Extreme Firewall Adjuster
Ford 11"Clutch Conversion
C&L MAF
WMS CAI
Aluminum Drive Shaft
95 V6 Vert: 4.2L swap, Trac Lock, Light Cam, Mac Shrorty Headers, More to come.
AlmostN8 is offline   Reply With Quote
Old 07-27-2005, 05:40 PM   #3
Send a message via AIM to whipster24 Send a message via Yahoo to whipster24
a chilton's manual would be useful to you. one of those strap type of oil filter wrenches is a big help with the coolant line that runs next to the filter. I can only turn mine a tiny bit at a time with it till it's loose enough to spin off by hand.
"This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future!"
-Adolf Hitler, 1935
whipster24 is offline   Reply With Quote
Old 07-27-2005, 05:41 PM   #4
check the articles, there is one on how to change your oil.
Old 07-27-2005, 05:42 PM   #5
I liek gramer
WhiteStang99's Avatar
Hey, you probably needed someone to show you how the first time too. Cut him some slack!
Old 07-27-2005, 05:59 PM   #6
Its not hard, but you need to be shown where things are until you do it a time or two (as with many aspects of life :chin: )
Old 07-28-2005, 08:19 AM   #7
MonteCitan's Avatar
drain plug, if its like my '02 is on the drivers side of the oil pan (from underneath of course) and should be a 16 millimeter bolt. If you can't break it loose at your angle hit it firmly with the palm of your hand a few times (the wrench, not the bolt) until it starts to break loose.. if it fights all the way out you might have to replace the plug as its stripped..
oil filter is at the front of the engine on the same side... will probably need an oil filter wrench to get it off Make SURE that the gasket comes off with the old one double gasket = bad..
putting a new filter on.. lightly oil the gasket on the filter (just put some oil on your finger and run it around the gasket) and then tighten it as much as you can by hand
Then snug up the plug (don't have to overtighten it, but snug it up enough... put in the 5 quarts of oil
at this point I crank the engine over til it catches, shut it off and repeat a few times to start to bring oil pressure up.. 0 oil pressure at 200 RPMS = better than 0 oil pressure at 1500+ rpms.. check to make sure its not leaking..then shut engine off, let it sit for ~30 seconds to a minute and check the oil..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 07-28-2005, 08:49 AM   #8
I liek gramer
http://www.mustangevolution.com/articles/oilchange/
Old 07-28-2005, 08:53 AM   #9
Originally Posted by WhiteStang99
Except don't use fram
-Adolf Hitler, 1935
Old 07-28-2005, 09:16 AM   #10
MonteCitan's Avatar
that article is okay but.. your car should have a 16 mmr plug rather than 15.. shouldn't have that much oil weepage and the oil filter would be mounted in a different spot
Old 07-28-2005, 10:24 AM   #11
Danger Dude's Avatar
25 plus years of engine building and have never had a problem with fram. Unless you can provide factual data and actual proof of Fram filters causing problems then all you are doing is passing along myths and false accusations.
Fram is a easy target because they are the largest filter maker in the world and own colse to 50% of the market. Every other filter company wants their buisness.
Old 08-01-2005, 11:00 PM   #12
MonteCitan's Avatar
Re: Oil Change Help
base level fram's don't have drainback flaps, the filtering surface has been proven to be much smaller than that of other filters.. and I think it has a different kind of bypass valve
I dunno I've seen a few studies, and seen them cut open in class, compared them side by side in person.. I've never touched a fram since..
Old 08-02-2005, 01:07 AM   #13
Send a message via AIM to 99stangin951
Re: Oil Change Help
UMMMMMMM...... thats the first time ive ever heard someone ask how to change oil, if you have to ask you better take it somewhere to be properly serviced if you do it yourself you might end up stripping the bolt, or worse....... what happened to auto shop in high school, dont they still teach it!!
99stangin951 is offline   Reply With Quote
Old 08-02-2005, 07:40 AM   #14
MonteCitan's Avatar
Re: Oil Change Help
many schools don't have an auto shop...
and there's a first time for everything on your car.. Changing the oil is just the beginning..
Old 08-02-2005, 07:41 AM   #15
Re: Oil Change Help
Well I was in a few year study cutting them in half and checking the oils for contaminants and all the name brand filters did what they were suppose to. There is no magic filter and you just throw them away every 3000 to 7000 miles depending on whether you use synthetic or regular oil.
But if you dont like Fram by all means dont use them. I sure as hell dont have stock with them or work for them. but the fact is most of the world uses Fram.
Old 08-02-2005, 01:23 PM   #16
Rick0636's Avatar
Re: Oil Change Help
I have also used a lot of Fram filters, but not always, lately been using the K&N oil filters with synthetic oils, I figure I need a great filter with running my oil 5-6000 miles between changes. I also used to use Wix, they seem a little hard to find now.
Old 08-02-2005, 01:42 PM   #17
01mineralgrey6's Avatar
Re: Oil Change Help
I personally use a motorcraft, but where i work we install frams all day.
-Tony
'99 cobra 'vert
Old 08-02-2005, 04:09 PM   #18
Re: Oil Change Help
I use to use Fram exclusively and really only stopped using them after reading a lot about them being lower quality. I've used motorcraft since and didn't notice any major problems with either. I did like the rubberized end on the frams though.
-Adolf Hitler, 1935
Old 08-02-2005, 05:04 PM   #19
douGT's Avatar
Re: Oil Change Help
i was just going to ask waht the oil nut size was becuase i forgot waht it was, but that article says its 15mm, thanks.
douGT is offline   Reply With Quote
Old 08-02-2005, 05:08 PM   #20
Re: Oil Change Help
it should be a 16mm
-Tony
'99 cobra 'vert
Old 08-02-2005, 05:21 PM   #21
douGT's Avatar
Re: Oil Change Help
well for safe keepings, i'll do them both.
Old 08-02-2005, 06:47 PM   #22
Re: Oil Change Help
I wish all were rubberized then it would be easier to take off and on by hand. Just a fact but 90% of mechanics and you guys overtighten oil filters. If you cannot take them off by hand they are to tight!!!!
Old 08-02-2005, 07:01 PM   #23
Re: Oil Change Help
i read a study performed on oil filters, the regular old ford filter done pretty good... good enough for me and they are cheap.
Old 08-02-2005, 07:25 PM   #24
Re: Oil Change Help
I only use a wrench to take it off cuz I don't have room to get my hands on it very well. But when I put it on I hand tighten it as far as I can get it
-Adolf Hitler, 1935
Old 08-02-2005, 08:12 PM   #25
Re: Oil Change Help
I wish all were rubberized then it would be easier to take off and on by hand. Just a fact but 90% of mechanics and you guys overtighten oil filters. If you cants take them off by hand they are to tight!!!!
I deal with that day in and day out, really pisses me off, espcially on alot of the toyotas where the filter sits right under the exhaust manifold, and the grease monkey that changed the oil before you did was afraid that it was gonna fall off...it wouldn't be so bad but were done changing the oil within 15mins of the car showing up. Kias can be a real biatch too..I hate my job
-Tony
'99 cobra 'vert
Old 08-02-2005, 08:13 PM   #26
Re: Oil Change Help
Are you a panzey boy????? MUHAHHAHAHAHA Just slide under the car and it is right there. You have to a get down there anyway to drain the oil!!!!
Old 08-02-2005, 09:27 PM   #27
Re: Oil Change Help
I get under the car for that anyway
my car has the radiator return line in the way so I can't get any leverage on the filter
-Adolf Hitler, 1935
Oil Change upton7 1996-2004 Mustang GT 13 05-11-2009 08:11 AM
Why Change your Oil???? Cajun JungleBoy The Bar 13 04-17-2007 01:59 PM
Oil Change 00StangV6 Pre-2005 V6 Mustang 15 06-09-2006 11:22 PM
the right way to do an oil change STEVE The Bar 11 07-25-2005 08:05 PM
Oil Change megax29 Pre-2005 V6 Mustang 31 09-03-2004 07:13 PM
08:17 AM
